BoostFlows fab and welding work
Old Nov 16, 2010 | 08:33 PM
  #26
9bells's Avatar
OG Fabricator
Default Re: BoostFlows fab and welding work
Originally Posted by all_motor_mike
i love reading what bells has to say......... ive never used 309 on my ms-ss (because my local welding shop doenst carry it) ive always used 308 for every thing that ss-ss and ms-ss. that being said are there any issue with using the 308 on mild to stainless bells?
mike
Yes. Several in fact.
Number one is that 309 is "overalloyed" for just this purpose. It is designed to be welded to low-alloy steels with stainless steels and have the weldement achieve a very similar metal to the stainless base metal. The main reason is to avoid martensite formation, and the other is to avoid excessive corrosion.
304/308/316 do not like to be diluted, or have the alloy amounts reduced drastically.
When you do this (welding to low-alloy or mild steels), the metal tends to form some martensite upon cooling. This will reduce the ductility, and increase the tendency to crack.
This is why it is so important not to weld mild steel with stainless filler metals just because they look nicer.
I could go into ferrite numbers, special nickel filler metals, and carbon content, but this is enough hi-jacking. Stick to 309. There are procedures in place for ms-ss, and none include 308 just because it will not pass the bend test due to martensite formation.
Old Dec 16, 2010 | 10:39 AM
  #27
quick_ls's Avatar
do you guys have sidewinders for K series in eg/integras?
Old Dec 16, 2010 | 11:40 AM
  #28
5.0 Killa's Avatar
This is the first I've heard of this. I actually remember asked one of my materials profs if welding mild with 308 would have any adverse effects. He didn't seem to think so, other than SS isn't as strong as mild, obviously. Good to know though, it's been years since I looked at phase diagrams and don't care to again haha.
Back purging and then going the extra mile and stress relieving the entire manifold would go along way to making a tubular manifold that wouldn't crack, or at least exceed the life of the vehicle. If I made manifolds that's what I would do
OP the manifold looks great, makes me want to pick up some 316 rod.
Old Dec 19, 2010 | 02:59 PM
  #29
BoostFlow.com's Avatar
Well its been really busy at the shop...we have been getting our company car ready for Ksport show. Making a display aswell. Oh and our new Kseiries manifold is out here are some pictures ....
Old Dec 19, 2010 | 07:48 PM
  #30
Kings Performance's Avatar
REALLY NICE WORK!
Keep up the good work!
Fernando @ Kings Performance
Old Dec 20, 2010 | 02:45 PM
  #31
MEGAME EXHAUST's Avatar
how do you know how to cut the tube at the right angle when routing around the engine ect when doing downpipe and full systems if you get what i mean??
do you just put the pipe where you want it and mark it against the pipe thats already there??
Old Dec 20, 2010 | 03:27 PM
  #32
Not sure what you mean...sorry having hard time picturing what your talking about ?
To get first placement we usually jig the manifold off of turbo placment.
Old Dec 20, 2010 | 03:49 PM
  #33
Jenkinsal2's Avatar
Sounds to me like he is trying to figure out how to decide on the cut angles for his tubing. As in how did you decide what angle to cut your tubing at when routing your manifold?
Old Dec 21, 2010 | 12:24 PM
  #34
well both really doing your manifolds and downpipes ect how do you measure on what angle to cut your tubing at? how do you know if it needs a 70 degree cut and not a 90 to join the pipes and butt up nice?
Old Dec 22, 2010 | 05:09 AM
  #35
RickyLee53's Avatar
Its all in the eye really, you get used to it. This is my method anyway, you can visualise in yours head how something "needs" to go. If i'm doing a production run i'll CAD model them.
To the op, keep up the good work, are you using 3/16th's filler on sch 40?
Old Dec 22, 2010 | 10:02 PM
  #36
AFFIRace's Avatar
You can also give yourself set degrees to work with. Only using 2 or 3 different ones and cut a boat load of each.
Old Dec 23, 2010 | 01:30 AM
  #37
RickyLee53's Avatar
This is what I normally do, 90, 45 and 22.5. However I also cut some "off centre 45's" i.e. 50 and 40, just to help things in tight areas.
Depends on what I'm doing.
Old Dec 23, 2010 | 03:42 AM
  #38
kl sounds good.... so theres no measurment tool to use to the measure the angles ect??
Old Dec 23, 2010 | 08:54 AM
  #39
AFFIRace's Avatar
Get some kind of angle finder. Find angles and mark em on the elbow. Then make fixtures to hold them in a horizontal saw to cut
Old Dec 23, 2010 | 09:01 PM
  #40
OoAoO's Avatar
I like your manifolds alot. Im hoping to order one very soon.
Old Dec 25, 2010 | 05:32 PM
  #41
h22killer's Avatar
i need a SFWD front mount T4 manifold for h22 can u make it? and how much chassis eg
Old Dec 25, 2010 | 06:32 PM
  #42
b00stFED's Avatar
sick manifolds... you guys making any top-mounts?
Old Dec 27, 2010 | 01:40 AM
  #43
4piston's Avatar
Yes, in theory, corrosion resistance is better. And, in many cases for 316 vs 304, it is. The exception is at high temp service. Both are rated for about the same service temperature roughly when it comes to most literature. The issue arises when the moly content in 316 allows precipitates to form, that eventually cause the weld to become brittle over time. This happens over long periods of exposure to the kinds of temps seen on turbo cars driven hard.
These formations, unlike many, are not alleviated by bringing the temperature of the material over the exposure temp that causes them in the first place. They can't be dissolved back into the metal. Now, we are talking amounts of time that will likely exceed most enthusiasts time with their toy cars, but it will happen. I use 316 on my exhaust/dp's for the same reason as everybody else, the colours. I also use it for extra corrosion resistance as mentioned, and because post-turbo parts will never see high temps for any extended time.
Manifolds in general are not something I'm keen on doing. Mostly, because all of you guys do a great job, and I don't need to build them to stay busy.
The other reason, is that they will all fail if driven long enough. I'm young, and I know that I will remain in contact with many customers for another 25 years. I offer lifetime warranty on anything I do. For this reason, I pick my battles. 100,000 miles will put enough cycles through any material to ruin it. Industry shows very well how fatigue and heat are very destructive. I have yet to see anything stand-up forever once you enter the 1000+ degree territory. I've seen many examples, and read alot of studies,etc on stainless and nickel alloys. I'm just passing some of it along as a caution. I'll tell you that 309 is one of the best rods to have around the shop if you could only carry one. It has excellent high heat properties, is the best for ss-ms, and does a hell of a job of ss-ss.
310 is another good rod to have around.
Wouldn't the corrosion resistance of 316 be even more important at those extreme temperatures? It is the chlorides that degrade the stainless, like salt on the road. The higher the temperature, the greater the effect of the chlorides on the stainless. Like Arrhenius says...the rate of corrosion from 121 C to 132 C is increased 50%. Imagine it at exhaust temps.
Old Dec 27, 2010 | 03:42 AM
  #44
Yes sir we do !
Old Dec 29, 2010 | 02:02 AM
  #45
justinagostini's Avatar
Well done. Looks like Good job done with concentration……..I am so much impressed by your welding work done in the pictures. Yes, in Automotive industry welding work is one of the significant works for sure.
Old Dec 29, 2010 | 06:40 AM
  #46
91jdmhatchback's Avatar
LOL wut?
Old Dec 29, 2010 | 08:08 PM
  #47
b00stFED's Avatar
sorry i forgot to say k series top mount.
Old Dec 30, 2010 | 07:46 AM
  #48
glenrx7's Avatar
Well in that case no, sorry we dont at this point. Are plan is to develop a kit for the ep3 civics. We are thinking the "ram horn" style top mount is going to be the best route.
We are also developing a forward facing manifold for the civic and integra...More cool pictures to come.
Boostflow.com
Old Dec 30, 2010 | 05:30 PM
  #49
Well been building alot of manifolds .just finished a ac ram horn and down pipe they are no fun due to the collector angle so much porting .....
Old Jan 24, 2011 | 09:27 PM
  #50
Been putting out some really nice work in our opinion (yes we are bias) haha!
Just wanted to share..
