bent traction bar & replacement
Old Sep 2, 2006 | 11:15 AM
weiRtech's Avatar
OG Fabricator
Default bent traction bar & replacement
i hacked up the old bar to make the new one, but you can see the nice bow left in the 1" square tube after one autocross session. the tires were rubbing the backs of the fender liners under hard braking.
i don't expect the new one to bend... i've added the two support arms to the stock crossmember bolt holes. at the very least, i've learned how not to make a traction bar and i've learned that my welds are strong enough to take some serious abuse and not show any signs of failure.
Old Sep 2, 2006 | 11:19 AM
siblues's Avatar
Default Re: bent traction bar & replacement (weiRtech)
Very nice job I always enjoy reading your posts you tend to fab up some great parts keep it up
Old Sep 2, 2006 | 11:25 AM
RCautoworks's Avatar
Good job
Old Sep 2, 2006 | 01:30 PM
Soccerking3000's Avatar
Default Re: bent traction bar & replacement (90blackcrx)
is it just spray painted or powdercoated? looks good either way
Old Sep 2, 2006 | 02:44 PM
tepid1's Avatar
Default Re: bent traction bar & replacement (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">is it just spray painted or powdercoated? looks good either way </TD></TR></TABLE>
Almost looks anodized....
Old Sep 2, 2006 | 03:33 PM
Default Re: bent traction bar & replacement (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">Almost looks anodized....</TD></TR></TABLE>
well thats what i thought but generally you anodize aluminum and i figured that the bars were made out of steel
Old Sep 2, 2006 | 11:13 PM
weiRtech's Avatar
OG Fabricator
just a spray bomb. primer, then paint. the paint kinda has a little bit of metal flake in it or something. it turned out not too bad. everything is mild steel on this one, as was the first.
Old Sep 3, 2006 | 06:30 AM
3s0n3's Avatar
i think you may have clearance issues on the header and radiator like i did. so i had to redesign mine from a stright bar like yours to a design with a kick in it, like what you see here on mine...
https://honda-tech.com/zerothread?id=1665396
if you have questions just ask, but nice job too! and i like the extra support bars on the ends!
Old Sep 3, 2006 | 07:21 AM
JDMCRX's Avatar
Nice work man
Old Sep 3, 2006 | 07:51 AM
weiRtech's Avatar
OG Fabricator
Default Re: (3s0n3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3s0n3 &raquo;</TD></TR><TR><TD CLASS="quote">i think you may have clearance issues on the header and radiator like i did. so i had to redesign mine from a stright bar like yours to a design with a kick in it, like what you see here on mine...
if you have questions just ask, but nice job too! and i like the extra support bars on the ends! </TD></TR></TABLE>
this is the 5th traction bar i've made for the car, i've sold past ones. don't think there will be an issue with clearances... trust me, this setup has been well thought out. these pics will give you an idea of where the bent one ran:
Old Sep 3, 2006 | 11:48 AM
HAUS's Avatar
Looks really good. is the bar anodized or painted?
Old Sep 3, 2006 | 04:46 PM
weiRtech's Avatar
OG Fabricator
Default Re: (weiRtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by weiRtech &raquo;</TD></TR><TR><TD CLASS="quote">just a spray bomb. primer, then paint. the paint kinda has a little bit of metal flake in it or something. it turned out not too bad. everything is mild steel on this one, as was the first.</TD></TR></TABLE>
Old Sep 3, 2006 | 07:00 PM
LD_EGSICK's Avatar
looks really well made. keep us updated on how it worked out
Old Sep 6, 2006 | 11:16 PM
HamiltonRex's Avatar
Default Re: (LD_EGSICK)
Looks almost identical to the JK Motorsports design.
Nice work!
Old Sep 7, 2006 | 06:00 PM
SQ is the SQUAD's Avatar
now thats some real engimeering. you got a place for me to stay so you can teach me? lol
vectorsolid
Suspension & Brakes
29
Mar 2, 2011 05:18 PM
Spectrum24x
Jan 5, 2006 09:06 AM
turbotypeR@SPEC
Jul 5, 2003 05:14 PM
nijia555
Jan 1, 2003 03:48 AM
user 996328629
Nov 21, 2002 03:36 PM
