2.5" to 3" options
Old Feb 19, 2014 | 05:15 AM
Freemananana's Avatar
Default 2.5" to 3" options
I have a 2.5" downpipe since my T3 garret has a 4 bolt 2.5" exhaust side. Just made sense to keep it 2.5". But my exhaust I have is a 3" Thermal R&D (actually just bought this) and I am wondering how to mate the 2 together. I haven't sized the Thermal Exhaust up under the car to see how much room/space I have to work with, but I am looking to see what my best option would be for connecting the two.
Should I go with a 2.5" or 3" flex pipe?
Am I stuck with a 2.5" pipe expanded to 3" to mate the two together?
Is there a way to use a vband to mate the two?
It's really tough finding some shots of this exhaust on an EF. I'm more of a visual learner and I'm having a tough time wrapping my head around exactly what the best way to go about this would be.
I know I should mount the exhaust and go from there, but I am hoping to order some more parts so I can get the exhaust installed sooner than later. This car is awful with a open downpipe and I hate it.
Thanks
EDIT: I personally know how to MIG weld and that's what I have at home. I have access to a TIG at work, but I've never used it. If I have to get some help with some welding, I can find someone to give me a hand.
Old Feb 19, 2014 | 06:08 AM
redboost10's Avatar
Default Re: 2.5" to 3" options
i would redo the downpipe and weld a 2.5-3" transition right on the 4 bolt flange. If you want to keep the 2.5" downpipe, the only way to get to 3" is using a transition...maybe weld it to the end of the downpipe, then use a 3" vband to connect the downpipe to the exhaust
Old Feb 19, 2014 | 06:25 AM
Basically answered my question right on the head.
I will probably just transition from the end of a 2.5" flex pipe to the 3" thermal exhaust. The downpipe fits well with my current manifold, I'm not sure a 3" downpipe with the adapter on the exhaust housing of the turbo would work. At least not how I feel I can fabricate it. I'm sure people have welded 3" vbands to their turbos and ran just fine. But I don't think that's up my alley.
Definitely appreciate it!
Old Feb 19, 2014 | 08:30 AM
bignorth's Avatar
i get all my transitions i use from http://www.mandrel-bends.com/catalog...less-2681.html
Old Feb 19, 2014 | 08:42 AM
A little on the high side when nappa sells em for $6. I know those are smoother, but for my use I think I can afford to go with a cheaper one for now.
Old Feb 19, 2014 | 03:52 PM
bignorth's Avatar
Your paying for quality tho. this is stainless, those are probably galvanized steel and are used in a tube expander instead of a rolled cone.
Old Feb 20, 2014 | 03:58 AM
I really don't want stainless since I don't have a TIG at home, which is where I'll be doing this. It's aluminized steel, which should last for 3-5 years. By then I hope to upgrade my manifold and need a new downpipe/adapter anyways.
Thanks though
Old Feb 20, 2014 | 05:53 AM
bignorth's Avatar
Thanks though
Then what will work just fine. Good luck!
Old Feb 20, 2014 | 06:47 AM
Charlie Moua's Avatar
i used similar piece. It was $30 cuase it was longer allowing the transition to be even more gradual.
Old Feb 20, 2014 | 06:58 AM
Down the line I would prefer to upgrade my manifold and get someone who is really good at welding to put a 3" Vband on my turbo so I can run a 3" downpipe to this exhaust. But until then, I'm not worried. I don't have enough power to sweat the little things. Main reason I bought this exhaust was due to my local shop sucking hard and the flange they welded on snapped and well.. long story short, my cat back isn't so hot around that area right now.
Old Mar 3, 2014 | 04:37 AM
So I did it. Excuse the ugly welds. Function>Form?
Here we go. I put on my Thermal Exhaust this weekend. This is the 3" Turbo exhaust from Thermal. I'm pretty pleased with it. My welding, not so much. This is what happens when you are a novice and you take a 3 month break.
Hanging it was pretty easy.
Connected the B pipe
Hung it up
And here is my gap
Time to fabricate something.
Sizing it up, going to cut it. As you can see this piece slipped into the other. It makes for an easier weld. It also means it can adjust. So I cut it short and pulled the pipe out to get the exhaust size. I also rotated the flange to make it all match up while under the car.
Here it is after the test fit
Here it is on the car.
That's fully welded up. I gave it the old sound test and it doesn't sound like there are any large leaks. But I'm going to grind back the welds (to look for holes) and run them again just to be safe. I have a video, but I'll have to upload it another time and post it here.
All in all. I'm happy with it. I am taking it back off like I said. I have to paint it and install my O2 bung for my wideband.
Old Mar 3, 2014 | 02:54 PM
bignorth's Avatar
I guess if it works it works. Good job man. Should hit it with a wire wheel to clean it up and make sure your welds are alright.
Old Mar 4, 2014 | 02:37 AM
It was ugly, just to test it. I took it off, took it to work, grinded it down, hit the welds again. Cleaned them up, wire brushed the whole thing, high temp paint on everything but the stainless mesh.
The main point was to show case what I used to go from Thermal's 3" Turbo Exhaust to my 2" B16A header. This is what I plan on doing for my 2.5" downpipe too.
alperx
Aug 22, 2011 06:52 AM
2k.civic.si
Nov 10, 2010 08:36 AM
davidluko
Apr 26, 2007 10:27 AM
b_ron007
Oct 28, 2004 01:49 PM
