this is a weird problem
ok so i took my car to a mechanic that does work out of his garage. He installed my motor. we swapped the computer from a p2p to a p2e. I had a y8 but now have a d16y7 bolted to a d16y8 transmission. The problem is when the car is running it will not go into ANY gears. When the car is off you can put it into 1st 2nd...you can even start the car in 1st gear and when you try to shift it into 2nd it wont go. I know for a fact the tranny is good. What is the problem here?
no. he did something wrong. there is an auto tranny and manual tranny, the motor is practically the same. just check your freaking clutch master cylinder, have someone press in the clutch and see if the shift fork moves...
well i called him and told him to check the fluid and the rod that goes from the clutch pedal. they are going to put everything back together tomorrow so i hope it works.
this is very frustrating because ive been without my car for 2 months. Not his fault, but mine for not having the $ to fix it
