Transmission & Drivetrain Gearboxes, Differentials, Clutches
Vx hatch
Old Nov 4, 2023 | 04:30 PM
Civic_girl348's Avatar
Default Vx hatch
So I have a 93 honda civic vx I recently bought. It's a manual and the other day i had my foot on the clutch cruising down a hill and the car made a grinding noise, and this happened a couple times. Then the car started having problems going into reverse or 5th and a weird noise while in gear almost like a faint tin whining noise. The noise isn't coming from the clutch it's came from the shifter which I haven't heard of before. Any ideas ?
Old Nov 4, 2023 | 05:29 PM
Ryanthegreat1's Avatar
Default Re: Vx hatch
Clutch in and in what gear going how fast?
Also don't cluch in to coast. Leave it in gear and take advantage of fuel cut decel. The VX with the tall gearing is great for this.
Probably input shaft bearings, all D series need them.
Old Nov 5, 2023 | 08:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
Agree about it likely being the ISB. My VX did the same thing about 20 years ago. The tinny whine you are hearing is likely metal-on-metal contact within the transmission. The reason you can't go into 5th and reverse is likely the broke parts piling up under the change holder inside the transmission. When my ISB exploded, it took out the input shaft seal too, and I was getting transmission oil leaking out from between the bellhousing and the engine block.
Depending on your level of comfort working on things, it's time to either take it to a shop or pull the transmission and open it up and see what you've got.
Ericpm96
Aug 27, 2021 12:04 PM
FlatlineSI28
Honda Civic (2006 - 2015)
19
Feb 17, 2008 09:45 AM
kajay1972
Aug 28, 2007 08:12 PM
zeckn0md
Honda Civic (2001 - 2005)
Mar 7, 2007 06:54 PM
banshee65
Jun 30, 2005 03:05 PM
