Transmission & Drivetrain Gearboxes, Differentials, Clutches
transmission installation
Old May 6, 2010 | 12:29 PM
illios's Avatar
Default transmission installation
doing a b-series swap
i bought the motor and tranny separately.
when i bought the motor, the seller told me he installed the clutch flywheel etc.. on the car all it needs is the tranny.
i have bought the tranny, cleaned all the oil on the tranny and drained the fluid. now i just need to know what else i will need to do to put the tranny on right.
i believe i just bolt it on since the clutch/flywheel is already on correct? then just fill in the tranny fluid with geuine honda tranny fluid.
i was told that i need to greese the gears n stuff? i just need a little info on everything i need to do or is it just bolt on and good to go?
Old May 6, 2010 | 11:21 PM
illios's Avatar
Default Re: transmission installation
bump
Old May 10, 2010 | 04:09 PM
fourdoorturbo's Avatar
I never heard of greasing the gears just put new transmission fluid in. Before you install the transmission see if you can get a hold of a clutch alignment tool to make sure the clutch is installed correctly otherwise it will be a pain in the *** to get the transmission to bolt up correctly
illios
May 9, 2010 09:44 PM
H.A.R.T b16a1crx
Aug 30, 2004 09:29 PM
yaoming
Mar 23, 2003 06:34 PM
JediPimpCrx
Oct 2, 2002 02:17 PM
