Transmission does not shift.
94 del sol with b16 transmission. Just rebuilt the transmission, when I put it together and had it on the car it shifted fine (Did not start the car, had other problems). Now the car doesn't go into any gear, I have not started it yet as I don't want to damage anything.
What are some things I should do/check?
Its the tranny, you can't move it enough to shift gears even with the linkage off. I was told if the interlock guide bolt is put on wrong, it will lock you out of certain or all gears. I think its all in my case. How would I go about properly installing it?
BDogggUT34
38
Apr 11, 2005 02:19 PM
coachkellum
Sep 9, 2004 02:03 PM
