Transmission & Drivetrain Gearboxes, Differentials, Clutches
trans fall out
Old Aug 12, 2012 | 05:50 AM
skaraider's Avatar
Default trans fall out
Ok so here s some background on the car b17 t70 turbo 5spd hydro gsr trans.
Took the car to the dyno the other day did 2 hours on the dyno which was about 34miles on the dyno we got the car tuned and all turned out great had good turnout.
So i trailer the car back home which was 175 miles from the dyno shop. unload the car drive it to my house 20 miles from where i dropped my trailer off at the barn. So i drive it to work this morning which did about...28miles one way, did great on the highway i didn't take it over 80 speed limit is 70. didn't hot rod it or anything i was just cruisin.
So i down shift to get off the interstate to slow down, the red light is about 1/4 mile off the exit. so im just slowing down, I take off at the red light and it feels like something is out of Balance. I pulled over checked my bolts holding the trans to the block, checks the axles, checked a few other things. everything seems fine. I started driving it was doing fine until I hit 40 MPH then it started shaking really bad.. so i pushed the clutch in and reved the engine to make sure it wasn't engine problems.. Rpms when up and came back down fine no misses or anything so at this point i know its the trans. So i pull into this fire station because im in a bad part of town, as im pulling in I loose all power to the trans feels like it slipped out of gear. No gears work now.
Any ideas? and yes there was fluid in it.
Old Aug 13, 2012 | 06:12 AM
MR.johnson's Avatar
Default Re: trans fall out
if the car is in gear can you roll it?
Old Aug 13, 2012 | 09:28 AM
skaraider's Avatar
yup stuck in gear, i pulled the speed sensor off and its covered in metal shavings.
Old Aug 13, 2012 | 10:44 AM
Honda Bull's Avatar
Differential failure.
skaraider
Aug 13, 2012 10:20 AM
bowtieboy911
Aug 27, 2011 03:19 PM
ECKOTYPER
May 11, 2006 02:40 PM
platinum00
Mar 2, 2005 04:34 AM
