Transmission & Drivetrain Gearboxes, Differentials, Clutches
Syncro problem??
Old Feb 17, 2009 | 05:14 PM
DjBij099's Avatar
Default Syncro problem??
Ok, I'm getting a trans. off one of my friends and the 5th gear is a problem he says. It's b16 hydro out of a 99-00 civic si. All the other gears work fine. Has no problem downshifting to any of the other gears. Upshifting to 5th is a bit tricky. If you go too fast it'll grind and you have to kind of look for 5th gear to go in, but it is there. Does this sound like a syncro problem??
Old Feb 18, 2009 | 06:32 PM
DjBij099's Avatar
Default Re: Syncro problem??
anyone??
Old Feb 18, 2009 | 07:15 PM
EJ8chu's Avatar
yes. More than likely its the synchro spring though. I have never understood how people mess up their 5th gears. Just take the case apart to find out
Old Feb 18, 2009 | 07:18 PM
Jas9848's Avatar
most likely a synchro and/or spring.
Old Feb 18, 2009 | 07:34 PM
EJ8chu's Avatar
It there a pop out if its in fifth at low rpms?
Old Feb 18, 2009 | 08:38 PM
Mista Bone's Avatar
D Tranny Guru
known issue with 5 gear on the B16 tranny, even a TSB rom Honda about it.
Tito559
Aug 2, 2011 08:57 AM
straychild
Classic Hondas
Jun 25, 2008 10:50 PM
Unidentified
May 29, 2006 10:55 AM
00itr
Oct 21, 2003 04:03 PM
maxpsi
Jun 16, 2003 01:40 PM
