Transmission & Drivetrain Gearboxes, Differentials, Clutches
Which shim do I use on my diff?
Old Aug 11, 2010 | 12:04 PM
925k20's Avatar
Default Which shim do I use on my diff?
I am putting a used itr lsd in my '96 gsr tranny. I purchased 2 new diff sealed ball bearings to put on it but I heard I might need to change the shim on the one of the new diff bearings. There is like 17 different sized shims from 1.00-1.75. Does anybody know what size I would need? Thanks for looking and for helping!
Old Aug 11, 2010 | 04:09 PM
93h2beg's Avatar
Default Re: Which shim do I use on my diff?
every case, diff and bearing set will be different, so there is not one size u will need. it has to be set up with just the diff and the case put back together and side clearance needs to be checked and adjusted till within spec. sorry i dont rememebr what they r right now.
Old Aug 12, 2010 | 10:50 AM
925k20's Avatar
Thanks for the info!
Old Aug 12, 2010 | 12:37 PM
Honda Bull's Avatar
Get the feeler gauges out and measure what the total distance of the space between the bearing and case is. Then look at what shim size will fill that space to end up with .000"-.004". Usually, I shim for around .001"-.002".
Old Aug 12, 2010 | 01:06 PM
925k20's Avatar
Thanks!
Old Aug 15, 2010 | 01:11 PM
sh!ft's Avatar
Who the fack changed my title?!
there is supposed to be 2 shims on the bottom and 1 on top when using a taper bearing setup. when using a shielded bearing setup, i believe it is okay to use the thicker of the 2 shims on the bottom and reuse the other one on top. it will make up for lost space since you are using the shielded bearings
any one care to chime in on this??
USDM-EK4*
15
May 5, 2009 12:36 PM
Silvertc
Apr 19, 2009 05:40 PM
powerneedy
Mar 21, 2008 05:39 AM
sir2k
Mar 5, 2003 11:33 PM
ZERO COOL
Jan 26, 2003 01:49 PM
