Transmission & Drivetrain Gearboxes, Differentials, Clutches
Remove CV boot via outer joint?
Old Dec 29, 2009 | 09:32 PM
beanbag's Avatar
Default Remove CV boot via outer joint?
I need to replace an outer CV boot. Most guides I have seen involve removing the inner CV boot and joint, and sliding off everything on that side. However, I have also seen an occasional comment where you can somehow take the outer joint off if you whack it with a hammer.
First off, is there a particular disadvantage to doing it this way?
Second, I am not really clear on the instructions. Which part are you supposed to whack, and is there a circlip or ring that you are supposed to take off first (not counting the actual boot)?
Old Dec 30, 2009 | 12:49 PM
95 Integra gsr's Avatar
Default Re: Remove CV boot via outer joint?
use a brass hummer it will dent and ding the hummer not the axles. and then just pull the boot off the same way.
retriever99
Jan 8, 2020 07:12 AM
Jimster480
Jan 22, 2010 10:58 AM
nickhans
Nov 12, 2005 01:16 PM
TeginRAGE
Jul 17, 2001 06:17 AM
xtrafastcivic
Jun 17, 2001 03:23 PM
