Transmission & Drivetrain Gearboxes, Differentials, Clutches
jdm lsd
Old Jan 20, 2012 | 05:00 AM
Gibby 123's Avatar
Default jdm lsd
Does anybody know what a jdm gsr transmission is worth in good condition with LSD (oem)???
Old Jan 20, 2012 | 05:53 AM
eg6 type-R's Avatar
Default Re: jdm lsd
jdm itr tranny (lsd) can easily b worth 1200
jdm gsr lsd i have seen them for about 700-800
but it all depends who is selling it to u..(private seller, shop,etc)
best bet is for u to call HMO or look at their online page and look for a lsd tranny
www.hmotorsonline.com
Old Jan 20, 2012 | 08:30 AM
Gearspeed-Performance's Avatar
Default Re: jdm lsd
One thing to keep in mind with LSD equipped JDM SiR-G trans is that it has a viscous type LSD that is prone to breakage. They typically break at the inner neck:
They also utilize a different bolt pattern that does not allow for any final drive changes unless you swap the differential out as well. So keep those things in mind. If you plan to daily drive the car and never swap the diff, then its a good buy if you can get it for around 700 in good condition. Even better if you can get it cheaper.
Speedra500
Feb 8, 2004 04:07 PM
gsrintegra1976
Oct 30, 2003 11:23 AM
BseriesMaddness
Oct 2, 2002 10:32 PM
