Transmission & Drivetrain Gearboxes, Differentials, Clutches
idk tranny problem
Old Mar 23, 2009 | 08:44 PM
top end tuner's Avatar
Default idk tranny problem
well i just finished putting in my motor and decided to take my car out for a test drive. as im driving i accelerate to 3k and as soon as i do it felt like the clutch was slipping. i gave it gas and changed gears and all it did was rev.
Every gear felt like it was in neutral because in every gear the car will not go. a can let go of the clutch pedal completely and the engine will not stall. i can push my car (had to ) even when its in gear.
the clutch was from a friend who told me it was good. help h-t is this a clutch problem or an internal transmission problem
Old Mar 24, 2009 | 07:02 AM
Default Re: idk tranny problem
bump
Old Mar 25, 2009 | 04:12 AM
Malcolm4591's Avatar
New User
yea i just had this problem to man haha, my problem when this happened is first it was my input shaft just kept spinning and not turn my gears so i got a new trans and fixed that prblem. The second time it happened to me it was cuz my passenger side axle pooped out a little bit. So check and make sure both axles going into Trans are completley in good. If its not the axle id say its the input shaft and that means u need to get a new trans.
i hate rice
21
Jun 18, 2006 11:21 AM
AaronJ
13
Nov 13, 2005 03:38 PM
1SlowSi
Feb 13, 2005 02:42 PM
deejaycherub
Oct 27, 2004 03:19 PM
Dorikamu
Nov 6, 2002 07:46 PM
