Transmission & Drivetrain Gearboxes, Differentials, Clutches
How to tell difference between final drives
Old Mar 14, 2009 | 08:46 PM
MindLess311's Avatar
Default How to tell difference between final drives
Ok heres the deal im looking to pick up an ls final drive. My buddy has a gsr, b16, type r, and ls. How do i tell which is which. Im guessing its easy to pick out the ls due to it being a diff ratio but i figured id help him figure out which is which for all of them.
Old Mar 14, 2009 | 09:41 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: How to tell difference between final drives
4.26 LS final drive:
-15 pinion teeth w/ 2 notches on end of gear tooth
-64 ring teeth w/ 2 different sized notches ...
4.40 final drive:
-for gsr/itr/b16's 15 tooth pinions, they have 3 notches ...
-gsr/itr 66 tooth rings have 1 middle notch ...
-b16 66 tooth have 2 different sized notches ...
Old Mar 15, 2009 | 09:22 AM
Thanks a bunch
Old Mar 15, 2009 | 04:13 PM
anytime.
Old Mar 15, 2009 | 05:32 PM
Mista Bone's Avatar
D Tranny Guru
also the diameter of the ring gear opening where it mounts to the diff.
myEKsedan
Sep 19, 2012 01:50 PM
ground_shaking
Nov 11, 2009 06:20 AM
b18bEKcoupe
Jun 28, 2007 11:18 PM
boostedblue
Sep 14, 2005 02:43 PM
GSRswapandslow.
Jul 12, 2004 11:03 AM
