Transmission & Drivetrain Gearboxes, Differentials, Clutches
HELP!! Y8 question
Old Dec 6, 2012 | 10:50 AM
doggworld1233's Avatar
Default HELP!! Y8 question
so i am in the process of puting in a phantom grip in my y8 i finaly got the case off and i find 3 bearing *****.. i have no clue where they go or where they came from i dont see any bad bearing
Old Dec 6, 2012 | 10:52 AM
Default Re: HELP!! Y8 question
i could only thing they could be from the screws with the springs maybe they are there to hold the springs in place against the bolts
Old Dec 6, 2012 | 03:54 PM
94EG8's Avatar
Seagull Management
Those would be the detent ***** for the shift forks. There are 3 detent bolts with springs under them. Replace the aluminum crush washers with new ones when reassembling or you will have shifting issues.
Old Dec 7, 2012 | 10:08 AM
Aquafina's Avatar
Make sure you didn't damage the detent bolts/springs (by not removing them).
I also highly recommend that you do NOT install the Phantom Grip.
90hatch268
Jun 29, 2006 08:28 PM
sortofindian
Mar 10, 2005 06:03 AM
Pfieff
Apr 1, 2004 01:58 PM
MrTodd
Sep 5, 2002 08:21 PM
crx(gator)
May 3, 2002 07:46 PM
