Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help needed
Old May 24, 2021 | 10:34 AM
Mornix Voldi's Avatar
Default Help needed
I have a 1998 honda civic vi ..obd2a wiring ..came with a cvt transmission..I change to m24a regular automatic transmission..my only problem just can't get shift selonoids wired to engine harness..how can I get signal to these
Old May 24, 2021 | 10:51 AM
Ryanthegreat1's Avatar
Default Re: Help needed
You will need a harness and PCM to match your engine and transmission combination. There is exactly zero compatibility between a CVT and a 4/5 speed automatic.
Old May 25, 2021 | 03:59 AM
thanks for the info..car have d15bz7 dual vtec engine...what will i need to put a manual transmission?
Old May 25, 2021 | 05:37 AM
Same answer, you will need a harness and PCM to match your engine and transmission combination.
And shift linkage, interior trim for a manual, a manual pedal box, clutch master and slave, plumbing for the hydraulics, and probably axles.
I don't know what market you are in, I assume not the US as we never had a CVT 1.5 in 1998. But a smart financial move might be to sell the CVT car and buy something else.
Old May 26, 2021 | 04:42 AM
thanks again for the info..I'm located in st Vincent and the Grenadines.in the Caribbean..
Syndacate
Jul 25, 2006 11:35 PM
