Is it hard to change out a automatic?
Is it hard to change out a 94 automatic accord transmission? See cause
I have a co worker who has a DA and is willing to give it to me if I can put in his new transmission on his 94 accord exect that the accord is automatic and Ive never done that. Im asking to see if anyone has done it and is it hard to do, it would be me and my cousin doing it so if there is a link for a step by step or if anyone could help out i would greatly appreciate it thanks
From: gravity rides everything...everything will fall, se GA/ne FL
basically just like swapping manual. instead of disconnecting linkages, you have to unbolt one shift postion cable going into the trans. disconnect fluid cooler lines. and before the trans comes off, you need to spin the crank/driveplate and unbolt the torque converter bolts so it separates.
iACC0RDi
Jul 19, 2005 10:06 PM
Eclipse
Aug 25, 2003 10:11 AM
