Transmission & Drivetrain Gearboxes, Differentials, Clutches
Flywheel surfacing
Old Mar 9, 2021 | 03:44 PM
Cody92's Avatar
Default Flywheel surfacing
Hey all. Recently did a clutch and didn't bother to do the flywheel. I know I should have. Anyways I get a little chatter at low rpm when going into gear. Well this go away with break in? Doesn't seem to bad and once car has been driven it goes away pretty much. Drives fine otherwise.
Old Mar 12, 2021 | 06:46 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Flywheel surfacing
Chatter is usually caused bu run-out problems. If that is the case, no amount of break in will fix the run-out problem.
Old Mar 12, 2021 | 07:15 AM
Cody92's Avatar
Well considering it's so minor should I worry? It's only when I go into first really. If I rev it a little I get nothing. Just smooth. My first time so I worry a lot about little things.
Old Mar 12, 2021 | 07:18 AM
Cody92's Avatar
Maybe this has something to do with it maybe not. I'm a one man show and I gravity bled until it felt good. Could bleeding be my issue in part?
Old Mar 24, 2021 | 03:21 PM
motoxxxman's Avatar
Is the disc sprung or unsprung? If it's unsprung, nothing will get rid of that chatter; unsprung discs are NOT meant for street use, only wrinklewall drag slicks
Old Mar 24, 2021 | 03:50 PM
Cody92's Avatar
Just a sprung stage 1. Basically oem just Amazon instead. Feels the same besides chatter.
Falloutkid90
Dec 24, 2015 03:20 AM
GoobyEP3
Nov 14, 2005 08:30 AM
ActiveAero
Jan 4, 2003 08:50 AM
ActiveAero
Dec 14, 2002 04:13 AM
