Transmission & Drivetrain Gearboxes, Differentials, Clutches
differential fluid change
Old Jan 12, 2020 | 02:33 PM
matsy's Avatar
Default differential fluid change
Took my 2017 Pilot to Honda for a 15,000 mile oil change. The rep and then her boss recommended changing the front differential fluid every 15,000 miles for $150. What is the appropriate mileage for this service??
Old Jan 12, 2020 | 03:41 PM
Ryanthegreat1's Avatar
Default Re: differential fluid change
Front differential fluid is the transmission fluid.
Maybe they were talking about the transfer case fluid if you have an AWD.
Old Jan 13, 2020 | 12:38 PM
matsy's Avatar
Thanks for the info. I have AWD. Recommendations for fluid change is 60,000 for tranny and transfer case. 30,000 for rear differential fluid but is this overkill ?
Old Jan 13, 2020 | 05:50 PM
15k is probably to early. The transfer case I would run at 30k to match the rear end. Only 0.5 liter of fluid in that thing and it lives right next to very hot exhaust components.
Old Jan 13, 2020 | 06:19 PM
D21X's Avatar
If you look at the Piloteers forum a lot of them get a code to change the rear diff at around 15k miles.
Old May 11, 2022 | 03:06 AM
easy129's Avatar
Better $150 than having to pay for a transmission replacement. Look at your owner’s manual and follow that. I would change it at 15K if you drive aggressively. I don’t know where you live but some dealers offer a discount.
Tmilli55
Honda CR-V & Element
Sep 26, 2018 01:27 PM
Canucksfan101
Feb 2, 2015 10:05 AM
dan_g
27
Oct 5, 2009 03:06 AM
CivicRaping
Mar 20, 2005 06:49 AM
