Transmission & Drivetrain Gearboxes, Differentials, Clutches
differential choices?
Old Jul 23, 2011 | 06:41 PM
Spawne32's Avatar
Default differential choices?
Hey guys, looking to swap from an open diff to a LSD, not sure what the best choice is out there, ive seen alot of them but all the ones i have seen dont have this spline on the end of the diff shown here in the pic with the red arrow.
Old Jul 23, 2011 | 08:07 PM
Gearspeed-Performance's Avatar
Default Re: differential choices?
You will need to pull the one off of your stock diff and transfer it over. Gently use a bearing type puller and make sure it gets a good even grip... Just got to be careful not to chip the teeth. Some LSDs have the gear built into them and come with their own speedo gear for the speedo assembly. But, M-Factory, Quaife, and Wavetrac will need a transfer of your stock gear over to thier differential.
For drag and daily driving with no chatter: Quaife, M-Factory, or Wavetrac...all three of them are awesome.
For Road racing and some daily driving with possible chatter depending on how they are set up: Carbonetic, Kaaz, or Cusco...also awesome for road racing as they allow adjustability of how they are engaged. They can be used in drag but, more suitable for road race/course applications. You can set them up for less chatter and using certain fluids can also help with chatter.
Old Jul 23, 2011 | 08:25 PM
Spawne32's Avatar
drag and daily will be the primary uses of the car, should i go with helical or clutch, and how much do i really need to be spending? Would an OEM diff from a type-r work? Really didnt want to dump 800 into just the diff but while im getting the trans upgraded (its actually an auto :x most people are confused on how that works with using the manual trans diffs) but if its worth the performance gain on the drag strip, its worth it.
Old Jul 23, 2011 | 09:33 PM
Well the M-Factory units are pretty affordable...the Wavetracs are also pretty close...the Quaife unit is a tad higher. As for the Type R diff...There are two different B series differential/ring gear bolt patterns: the GSR/Type R and the B16/LS. So just depends on the bolt pattern for the ring gear you will be using. Interested to see this conversion.
Old Jul 24, 2011 | 06:36 AM
Spawne32's Avatar
alrighty thanks for the information, ill have to pick up a spare trans to pull apart first and see what the diff looks like and match it up to the particular style i need.
Old Jul 28, 2011 | 03:11 AM
civickiller's Avatar
you can get a obx diff if you dont mind buying $40 worth of washers and bolts then putting them in the diff. obx is roughly around 400 if you dont mind doing alittle bit of work overhauling it
it handled 266whp in my car with over 100 passes
Old Jul 28, 2011 | 06:00 AM
Russyo's Avatar
my OBX in my GSR has been handling 500+ for a good while. Lots of highway pulls on it.
Just now upgraded the washers and bolts, because I broke 4th gear so it was apart already.
Old Jul 28, 2011 | 08:54 AM
Spawne32's Avatar
i have been actually considering that i just have concerns about taking it apart and putting it back together right lol also, where would i find upgraded washers and such that would work properly for the diff?
Old Jul 28, 2011 | 08:58 AM
Russyo's Avatar
http://rbryant.freeshell.org/obx_washers.htm
There's a guide and he sells the washers and bolts upgrades. I just got some from him this last week!
Old Jul 29, 2011 | 01:45 PM
MR.johnson's Avatar
no on the obx.
just buy a mfactory and do it right.
Old Jul 29, 2011 | 01:55 PM
Russyo's Avatar
OBX is the **** as far as I'm concerned. If rebuilt correctly it seems to hold a ton of power with zero issues. Not sure why anyone wouldn't want one. Unless you make some insane power and have every other upgrade where the trans is the weak spot. But it's all opinion at this point.
Old Jul 29, 2011 | 10:19 PM
Mista Bone's Avatar
D Tranny Guru
Yep, bad castings, run out issues, washers in wrong, threads not fully tapped. Wood inside the diff,
Figure 2 hours to "fix" an OBX + parts.
Then you have to shim the damn thing, that can be another hour if you have to make a custom shim. Have fun getting the ring gear bolts on. a 14mm thin wall socket wil only last for three OBX's.
Or you can buy an MFactory, drop it in, check shim clearance, button up the tranny. I've installed 5-6 MF's now, I've yet to have to change a shim.
In the end, the price will be the same. Make your installer happy, get the better LSD.
I've only messed with ONE OBX since Aquafina and I had run out issues, it was an OBX that I'd installed before.
HINT: B series oil control rings don't work as diff shims. They are too brittle and crack.
Old Aug 3, 2011 | 06:20 AM
CDecker0218's Avatar
I just installed my Quaife LSD into my new gsr tranny which will be going in shortly. Price is fair and a proven product! Mfactory is a good choice too.
Old Aug 5, 2011 | 12:37 AM
Mista Bone's Avatar
D Tranny Guru
tubthumping
Old Aug 11, 2011 | 02:49 PM
Rob97'SH's Avatar
so which is better Mfactory vs Quaife? price not being an issue
Old Aug 11, 2011 | 03:42 PM
Quaife has been around a lot longer and are made in the UK. M-Factory is also a well made product and we have not had one single issue with them. Both have a lifetime warranty! Tough one!
mach3lude
Aug 29, 2011 07:18 AM
ineedavtec
Jul 21, 2011 05:47 AM
lastturn
Feb 22, 2006 08:07 PM
Shmaa
May 24, 2005 12:52 AM
PupaScoopa
Apr 8, 2003 10:01 AM
