Transmission & Drivetrain Gearboxes, Differentials, Clutches
CRV Throwing Code p1768 and Only Shifts Manually
Old Jan 30, 2021 | 06:59 PM
Toat13's Avatar
Default CRV Throwing Code p1768 and Only Shifts Manually
Got a 01 CRV, 4wd auto. Just swapped in a new jdm motor. after some tinkering got the engine running real nice, until I tried to drive it. Was flashing the D light but hadn't checked codes yet. Tried to drive it, pretty sure the car was stuck in 4th unless I manually switched to other gears. Checked for codes, I got p1768 for the trans. Replaced the lower shift solenoid, didn't fix anything. Has new trans fluid, and the transmission also worked fine before the swap, so I'm completely lost as to where I've gone wrong. Really would like to avoid taking it to a mechanics shop, seeing as I'm not wanting to be charged an arm and a leg for something I know I could do myself. Any tips?
Old Jan 31, 2021 | 02:40 PM
Toat13's Avatar
Default Re: CRV Throwing Code p1768 and Only Shifts Manually
bump, any advice?
Old Dec 20, 2025 | 09:05 AM
garciabro's Avatar
Originally Posted by Toat13
bump, any advice?
hey man any chance you figured it out? My civic is having a similar issue
Aradin
Jun 23, 2019 11:39 PM
hexavolt
Dec 27, 2017 09:09 PM
Datto
Apr 7, 2013 06:21 AM
vtecgsr98
Mar 25, 2006 12:50 PM
