Transmission & Drivetrain Gearboxes, Differentials, Clutches
Big Vss problem on 93 integra . Help
Old Nov 28, 2008 | 04:43 PM
DraginTeg93's Avatar
Default Big Vss problem on 93 integra . Help
ok so i having a problem with my Vss , Speedometer and speedometer cable .. First my speedo cable went back so i didnt get one for a couple of days cuz it was on back order drove around my car and after 3 -4 miles the light would come on .. so i took my car apart got the new one put it in and now the light comes on right away .. the needle gos from 20 mph to 80 mhp . with the new cable .. ?? im lost .. so i take everything out of the car .. take the cluster and the cable put a drill on the end of it and it works fine all the way up 120mph. then i put the vss on and it works FINE . so i put everything back in the car and the speedometer needle wants to jump all around ... i drove it with the old cable broken for 3 days a code after 3-4 miles . new cable needle bonces around and light right away ...
Any helpp .. anyone have this problem .. its a 1993 integra ..
Old Nov 29, 2008 | 03:58 AM
gibsanez's Avatar
You probably don't have the cable plugged all the way into the cluster, simple as that. It's a very basic setup, there's not much that can go wrong.
Old Nov 29, 2008 | 01:42 PM
pluged all the way in .. brand new cable ..
Old Nov 29, 2008 | 04:43 PM
gibsanez's Avatar
Could be a faulty speedo gauge, you can swap them out between clusters. You could try that, should be a cheap fix.
Old Nov 30, 2008 | 05:36 PM
ill try that cuz it works outside of the car fine . ill shall see thanks
Old Dec 1, 2008 | 10:17 AM
lsneo's Avatar
follow the cable and make sure that its not crimped all the way. Also make sure it clips in all the way on both sides.
Old Dec 1, 2008 | 07:23 PM
i did that . brand new cable and the clips all the way in .. can u just change out the speedo gauge between cluster .
GPC91
Sep 17, 2012 01:11 PM
DraginTeg93
Dec 4, 2008 10:00 AM
saikouEF8
Mar 28, 2006 09:42 AM
PA MATT
Apr 6, 2004 07:40 PM
PhatHardy
Jan 6, 2003 08:01 AM
