Transmission & Drivetrain Gearboxes, Differentials, Clutches
B Series shifting issues
Old Mar 19, 2022 | 01:30 PM
David Popoff's Avatar
Default B Series shifting issues
After swapping a b16 into my Civic the shifter will go easily into 1,3,5, but has issues going into 2,4,R. With the shift linkage off I can shift through all the gears using a screwdriver through the transmission pin/linkage. I've tried replacing the bushings on the shifter with no improvement. I plan on pulling the entire shift linkage and shifter assembly and replacing any worn out parts.
Is there anything besides the shift linkage that could cause this issue, or do you think the shift linkage will solve my issues
Old Mar 20, 2022 | 07:11 AM
Aquafina's Avatar
Default Re: B Series shifting issues
Sounds like the shifter/linkage is hitting something or you're using the wrong linkage.
woodenchef
Nov 27, 2012 09:10 AM
kp
Nov 30, 2011 06:37 AM
civicsi0721
Feb 25, 2009 07:17 PM
CRX MASE
Sep 6, 2006 07:52 PM
Luserkid
11
Jun 30, 2004 04:17 PM
