Transmission & Drivetrain Gearboxes, Differentials, Clutches
Abs driveshaft
Old May 13, 2014 | 07:31 PM
Matt17t's Avatar
Default Abs driveshaft
Hi just wondering if an abs driveshaft would fit into a car without abs brakes?
My car is a 94 honda integra b18c Manuel, I've found a driveshaft from a 97 but it has abs brakes.
Someone said you can just remove the abs ring and it should fit?
Old May 13, 2014 | 08:06 PM
F22Master's Avatar
Default Re: Abs driveshaft
You shouldnt need to remove the abs ring... Just put the axle in, it will work just fine.
lesagueneen
Honda Fit
Jul 22, 2018 10:11 AM
D-Rizzle3
Aug 18, 2008 02:27 PM
Fraggle
Nov 2, 2003 11:03 AM
