Transmission & Drivetrain Gearboxes, Differentials, Clutches
1st Gear Problem
Old Oct 9, 2014 | 01:28 PM
prakhash's Avatar
Default 1st Gear Problem
My car keeps having trouble going into 1st gear. I'll be at a stop light and it won't go in, and then I move the shifter right and left, and then it goes in. I have a Y80 5 speed transmission on an Integra. I don't know what exactly it could be but here are a few things I think may or may not be the problem:
1) My rubber floor mat might be too thick, so it is restricting the clutch pedal from going all the way in. I doubt this is the case because I have tried moving the mat back and even if I push the clutch as hard as I can, it still does it.
2) Transmission fluid might not be the problem because I just did a flush last season, and I have driven about 5000km on it only.
3) After installing my new short shifter, the shifter wasn't flush with the linkage, so it was making rattling noises. I added a couple of washers on either side of the shifter, and then bolted it to the linkage. It still makes the rattling noises because it's kind of loose. I need to fix the number of washers or get a new linkage. I don't know if this would prevent the transmission not going into 1st gear though.
Any suggestions?
LSxVQ35
Sep 7, 2008 04:21 PM
ImPuLsIvE
Honda Civic (2001 - 2005)
12
Nov 6, 2007 03:48 AM
-iLLuZioN-B18C1
Jan 9, 2003 08:02 PM
infamousALLMTR
Jan 30, 2002 09:30 AM
