zc swap, will it work
Old Sep 25, 2003 | 07:10 PM
JONBLAZE55555's Avatar
Default zc swap, will it work
I have a '94 Honda civic lx. it currently has a d15 engine. My friend blew his trans in his crx. Now, he wants to get the b16 swap and is selling his zc. he told me it will bolt right into my trans. is this true. and if im correct i have to change my ecu to obd0 right? please help me out i want to make sure this swap will work.
Modified by JONBLAZE55555 at 11:31 PM 9/25/2003
Old Sep 25, 2003 | 07:30 PM
Default Re: zc swap, will it work (JONBLAZE55555)
night time bump
Old Sep 25, 2003 | 07:36 PM
blah13's Avatar
The tranny will bolt up, and you'll need to run a PM7 or PG7 ECU for obd-0, the thing I'm not sure of is if it wires right up to your engine harness or ecu harness. And I think you may need the injector resistor box, I'm not sure if your injectors are saturated or peak and hold. So theres a few more questions you'll need answered.
Old Sep 25, 2003 | 07:41 PM
Default Re: zc swap, will it work (blah13)
its coming with the injectors, fuel rail, headers, ecu, msd ignition, cold air intake, and throttle body. basically every thing but the trany and axles
Old Sep 25, 2003 | 07:51 PM
blah13's Avatar
After doing some quick looking the 92-95 Si and EX have saturated injectors but they dont list dx or lx...but we (88-91) have peak-hold injectors. So if you also have saturated injectors you will need a resistor box from a mpfi 88-91 civic/crx as the resistances are different.
Look around for obd-1 to obd-0 conversion.
Old Sep 26, 2003 | 04:01 AM
thanks, any one else
Old Sep 26, 2003 | 05:56 AM
Don Napier's Avatar
Import Alliance
post in hybrid or the eg forum. There might be someone who reads those posts that has one already done that might be able to help.
datsol94
Feb 21, 2012 03:52 PM
ludecrasy87
Nov 29, 2006 12:24 PM
DarknessInside51
May 31, 2004 04:20 PM
goforbroke
Apr 17, 2004 08:26 PM
