zc dohc problem!
Old Jan 11, 2012 | 04:15 PM
chirrin's Avatar
Icon3 zc dohc problem!
hi guys. I have a 89 honda crx si with a zc dohc. this is my problem.
car was driving fine, went home, parked the car. Next day i wanted to turn it on
and it didnt.
After a couple attempts the engine turned but it seemed like 2 pistons only were working, sounded kind like a old vw bug haha. ho well so.
i check spark every single hone fire normaly, inspected and tested injector and they were perfect, inspected timing, i opened the valve cover to be a 100 that the holes on the cams were aligned withthe holes on the head. Totally exelent timing. tdc aligned too
i Checked for blown head gasket but it doesnt seem it is, no sweet smell, no radiator spitting out coolant.
ecu not trowing codes at all, and tested with a new one and still the same.
ho and the car doesnt stay on, so could it be head gasket, or do i need to check something else?
thanks guys i apreciate it
Old Jan 12, 2012 | 08:36 PM
zach53's Avatar
Default Re: zc dohc problem!
i would check the main relay.
Old Jan 12, 2012 | 09:33 PM
chirrin's Avatar
well those are not symtoms of main relay, but hey i found the problem myself, i dont know if is to common but the rocker arm detached from the valve and it was not working and stuck, i would send a pic but is a pain in the *** trying to upload it thanks.
what does it mean that my posted got moved?
jayyjimm
Jul 16, 2015 08:28 PM
dturn89
Jun 1, 2010 08:35 AM
civic46
Feb 3, 2007 03:33 AM
k24ej8
Nov 7, 2006 04:51 PM
Digitalcivic
Oct 1, 2003 12:27 AM
