zc crx
Old May 27, 2009 | 11:29 AM
crex-ef's Avatar
Default zc crx
hey hows it going well i been trying to get my car to run and well hAVENT HAD ANY LUCK.IF ANY ONE IN THE BAY AREA SAN JOSE. CAN HELP.. HIT ME UP URGENT!!
Old May 27, 2009 | 04:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: zc crx
Exactly what is happening or not happening?
MM&Y of car and what has been done to it?
Do you have power, do headlights, horn and hazard lights work?
Do you have ign. power, does cluster "light up", can you hear the fuel pump prime the fuel system when ign. is turned to run, [not start]?
Does the starter motor crank the engine?
Have you checked for spark, is there power on the black/yellow lead going to the distributor assembly when ign. switch is in run?
Have you got fuel pressure?
I there power at the injectors, [lead that is the same color on all injectors] when ign. switch is in run and start?
Please answer all the above and I will see if I can help. 94
H22SHtec
Sep 25, 2023 09:17 PM
dslatet455
Mar 15, 2018 10:18 PM
PeterTheWolf
Jul 17, 2010 02:32 PM
liquidrider
May 25, 2009 10:10 PM
ghost_ryder35
Mar 24, 2004 07:17 AM
