y1 gears in ys1 case HELP!!
i have a jdm y1 tranny with a blown up diff and good synchros. i also have a ys1 ( 92 gsr) tranny with a bad 2nd gear. i believe the synchro is bad on the ys1 but i don't have the money to buy new ones. im curious if i can just take the gears out of the y1 and stick them directly into the ys1 case keeping the ys1 final drive?? or are there differences between these two cable trannies..
also would this be a performance benefit over the origional y1 tranny??
bump i need help people. i would just replace the synchros but the kid that had the car beore me said he did that in the ys1 and 2nd gear still didn't work so im guessing there is a possile shifter fork bent etc.. bump
They are not interchangeable shaft wise...maybe just the 1st gear synchro and possibly second depending if the YS-1 is LS or not. You may need more than a synchro...it is usually the synchro, sleeve, and the gear. Possibly the fork depending on condition...Highly doubt that it is bent...you need retard strength to bend those. Possibly a groove on the fork.
the ys-1 is gsr. . would i be best off just taking the transmission to a shop and having it looked at? because honestly the synchro's and gears all look fine on it and yet it STILL does not have 2nd gear 75% of the time, it would feel ike it was in then i would let out on the clutch and it would just grind... then sometimes ( rarely) it would go in stay in if i held it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx »</TD></TR><TR><TD CLASS="quote">the ys-1 is gsr. . would i be best off just taking the transmission to a shop and having it looked at? because honestly the synchro's and gears all look fine on it and yet it STILL does not have 2nd gear 75% of the time, it would feel ike it was in then i would let out on the clutch and it would just grind... then sometimes ( rarely) it would go in stay in if i held it..</TD></TR></TABLE>it sounds like a worn 1/2 shift fork, just take it to a shop and get it fixed! btw things might look fine, if you don't really know what to look for!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokey2.0 »</TD></TR><TR><TD CLASS="quote">it sounds like a worn 1/2 shift fork, just take it to a shop and get it fixed! btw things might look fine, if you don't really know what to look for!</TD></TR></TABLE>
Give it a try and have it professionally looked at
could it possibly be a missing spacer that is causing this.. becasue the synchros are BRAND new and look great.. i had a 2nd opinion on this and im just wondering if anyone has experience with missing spacers.. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow91crx »</TD></TR><TR><TD CLASS="quote">could it possibly be a missing spacer that is causing this.. becasue the synchros are BRAND new and look great.. i had a 2nd opinion on this and im just wondering if anyone has experience with missing spacers.. thanks</TD></TR></TABLE>from my past experience, if you miss any of the spacers on the transmission things wont line up! the gears will spin just like they should, with the case open. but once you close the case, the mainshaft wont budge! btw how did your pressure plate look, if the plate is broken(more than one rivet broken) it will make getting into gears hard at mid to high rpms!
mrx
18
Feb 25, 2013 05:21 AM
