WTF: Only 2 valves open?
Old Mar 8, 2004 | 08:22 AM
OTT's Avatar
OTT
Default WTF: Only 2 valves open?
Just looking through my exhaust ports with the upper zorst manifold off I saw Piston 1's valves (right-most side of the engine) were in the open position but all the others are closed. Is this normal? is there a point where only 2x zorst valves are open at anyone time? and if it isnt normal then what shoul I do to correct it ?
Oh an its a H22a OBD1
Old Mar 8, 2004 | 10:49 AM
JimBlake's Avatar
Default Re: WTF: Only 2 valves open? (OTT)
Supposed to be that way... Rotate the crank (forwards only...) You'll see #3 valves open when #1 close, then #4 then #2... Only one cylinder is in the exhaust stroke at a time.
Old Mar 8, 2004 | 11:15 AM
TeamCracka's Avatar
Default Re: WTF: Only 2 valves open? (JimBlake)
Yeah man, firing order is 1-3-4-2 and since our motors are 4 stage (intake, compression, ignition, exhaust expulsion), no two cylinders are in the same stage at the same time.
If you want to see what it looks like animated, goto the link in my signature and look at the last page for my latest animation that shows how the valve train operates.
Hope that helps.
Old Mar 9, 2004 | 02:42 AM
OTT's Avatar
OTT
Phew, I was thinking that two sets should be open at any one time Cheers.
Its been sitting in the garagea couple of months now, finished installing the cradle, suispension all torqued up to spec so just gotta get it aligned and its back on the road.
W95civicEXcoupe
300
Dec 23, 2015 08:42 PM
an2ny888
Aug 25, 2014 07:25 AM
lude98SH
21
Dec 13, 2006 01:36 PM
Boost2NA
Apr 20, 2004 06:06 PM
jdmkrazie
Jan 12, 2004 07:15 AM
