WTF happended! HELP
Old Jun 26, 2009 | 07:02 AM
DuhQbnSiLo's Avatar
Default WTF happended! HELP
I have a B16A2
I forgot what its called but the hose that goes from the intake manifold to the valve under it.
I didn't have it. both sided were closed off so i got the hose for it yesterday and installed it.
This mourning I turn my car on and my idle jumps to 2500.
Wtf happended? It didn't do it before when they were both closed.
Old Jun 26, 2009 | 12:43 PM
delsolproblems's Avatar
Default Re: WTF happended! HELP
You mean the hose that goes to the black canister? Specify the location of the aforementioned valve.
Old Jun 26, 2009 | 02:49 PM
Mike@CCT's Avatar
Formerly Mike@TSR
PCV valve im guessing. Now you probably have a huge vacuum leak.
Old Jun 26, 2009 | 06:05 PM
DuhQbnSiLo's Avatar
Yes the PCV valve
I plugged them back up and the car is running fine again... i guess ill keep it that way
Old Jun 26, 2009 | 07:16 PM
srmofo's Avatar
well thats not the best idea. It is to vent your crankcase. No vent leads to Excessive pressure which leads to oil leaks everywhere....eventually. You hooked it up wrong the first time, try again, there should be no vacuum leaks anywhere. Locate it with a can of carb cleaner or something similar
Old Jun 26, 2009 | 08:34 PM
You should replace the PCV valve and hook it back up.
RiversideS13
11
Jul 21, 2007 08:11 AM
AZNracerx1989
Jan 27, 2006 09:38 PM
byronl
Mar 19, 2005 10:24 PM
Reelizmpro
Nov 17, 2004 05:16 PM
