AN Wrenches - Where to buy
Old Jan 24, 2009 | 01:03 PM
patrick4588's Avatar
Default AN Wrenches - Where to buy
i need a place local that would have them, so if any chain stores carry them, that would be great.
Old Jan 24, 2009 | 01:08 PM
2point1's Avatar
Default Re: AN Wrenches - Where to buy
summitracing.com
Old Jan 24, 2009 | 01:14 PM
yeah i know where i can order them. i was seeing if any local hardware/tool stores sold them. like maybe an ace, autozone, sears, etc.
Old Jan 24, 2009 | 01:46 PM
rotten's Avatar
Seriously doubt it.
You could try a aerospace, helicopter supply place if you have one in your area.
In a pinch you can use regular wrenches.
Old Jan 24, 2009 | 02:48 PM
rip94delsol's Avatar
there is a company that sells adjustable an wrenches. might be btter off that way!
Old Jan 24, 2009 | 03:00 PM
NJIN BUILDR's Avatar
Some speed shops may have them.I have never seen any at any local stores.Check the plumping dept at you hardware or Lowes/Home depot.They make some short ,narrow ,wide opening adjustable wrenches if you have a tight spot your working in.Other wise just use any wrench that fits with some tape on the jaws if your worried about the finish.
Old Jan 24, 2009 | 03:02 PM
Lubo_25's Avatar
i just made mine...never really know why they charge so much for them...
Old Jan 24, 2009 | 03:38 PM
they charge so much cause the are more than likely cnc made which does cost for setup and charge by the minute or second some places.
Besides that aluminum is not cheap and anodizing is not free either!
Old Jan 26, 2009 | 05:54 PM
rotten's Avatar
I've never understood it either tho. I don't want anodized ones. Can probably cut with laser if need be, and then just tumble finish it.
Old Jan 26, 2009 | 06:02 PM
BlakeJ53's Avatar
snapon
Old Jan 26, 2009 | 06:32 PM
srmofo's Avatar
In ohio we have aeroquip stores that carry them, you could check with the Parker store or any other hydraulic supply store....does fastenal have them, Ive always just used regular wrenches...carefully
russianvr4
Welding / Fabrication
Jul 9, 2009 04:06 AM
Boarderx192
Dec 17, 2007 09:11 PM
Sims
Oct 1, 2007 04:44 PM
Justin Olson
12
Sep 23, 2007 09:26 AM
