Would you run this piston? dropped valve :(
Old Nov 11, 2008 | 06:52 PM
N1 Andy's Avatar
R.I.P. Andy
Default Would you run this piston? dropped valve :(
I dropped a valve right when I was cranking the motor over to start it after driving it hard for 3 days. The car didn't even start, I heard the knocking around when turning it over and stopped immediately, I feel fortunate it didnt happen at 9k haha.
I don't need to hear flaming about me being dumb or ghetto, I AM dumb, ghetto, and cheap lol, no need to tell me about it. If you think it may work then I'll probably use it.
I don't want to take it out if I don't have to because the motor is new, the rings have seated, and I just put it in, I don't want to go through all that **** again.
Its a ls bottom end with b16 pistons, p72 head (rip), toda b's, supertech springs and retainers.
Old Nov 11, 2008 | 07:56 PM
mtber's Avatar
Default Re: Would you run this piston? dropped valve :( (N1 Andy)
Replace the piston as that damage in the piston will cause a hot spot.
Old Nov 12, 2008 | 07:08 AM
sackdz's Avatar
I can't see the picture because of my firewall, but if you do use it, file down any edges to avoid hot spots.
Old Nov 12, 2008 | 09:30 AM
srmofo's Avatar
Default Re: Would you run this piston? dropped valve :( (sackdz)
I somehow sucked a bolt into my cylinder, it wasnt as bad as yours, but I took it out anyways and took it to the machine shop....they hit it with some glass beads and you can hardly tell it was damaged
Old Nov 12, 2008 | 11:55 PM
siregcivic's Avatar
Default Re: Would you run this piston? dropped valve :( (srmofo)
how do you drop a valve, i really never understood it, i thought you could only do it from over revving?
Old Nov 13, 2008 | 07:35 PM
sackdz's Avatar
Default Re: Would you run this piston? dropped valve :( (siregcivic)
or broken retainer from a bad cam
Old Nov 13, 2008 | 09:16 PM
N1 Andy's Avatar
R.I.P. Andy
I personally dropped a valve because I was a dumbass and impatient and did not do a valve adjustment before starting a fresh motor, the valve lash was way too tight (.000 in some spots) which caused the timing belt to slip, which bent the valves, and 3 days later dropped one. Just the head pf the valve just broke off, so at least I know my springs/retainer install was not faulty, the keepers were still in the retainer when I pulled the head, doing their job, just only holding a stem not a whole valve haha.
Old Nov 15, 2008 | 12:47 PM
projectTeG's Avatar
most of the time the face of the valve breaks off and takes a trip.
(overrev cause bent valve and stress cracks, then it breaks off)
Old Nov 15, 2008 | 01:50 PM
NJIN BUILDR's Avatar
You "might" get away with that with a forged piston but the stock ones are cast.There is a good chance that it is cracked now (you might even see it from under the dome).When it fails it will break into a hundred pieces and ruin the block and head.
Old Nov 15, 2008 | 07:02 PM
sackdz's Avatar
what does the head look like?
Old Nov 15, 2008 | 11:39 PM
Rob91DA's Avatar
Andy, get a hold of me, I have the stock JDM bottom end off my swap, The pistons are good and I happen to want some GSR Pistons, maybe we can work something out, I also have a bunch of extra GSR valves. Hit me up if you're interested.
Old Nov 16, 2008 | 07:08 AM
N1 Andy's Avatar
R.I.P. Andy
Default Re: (sackdz)
the head is not bad, it just needs 3 new guides and 1 new seat, theres just a few tiny knicks in the c chamber, none are even deep, its at the machine shop getting a valve job, new valves, a new seat and new guides.
thanks rob, I already got rid of my old gsr pistons though. And I ordered Supertech valves on friday, did you have a jdm b16?
Old Nov 16, 2008 | 07:59 AM
Rob91DA's Avatar
Default Re: (N1 Andy)
Yeah, had the JDM B16 swap in my DA forever, I just swapped to a B18A bottom end Joe had, I need to re-ring it though, it uses a little oil. And hey, IM me about the vision seat, Alex wants to talk to you about the Homie Hookup pricing.
Old Nov 18, 2008 | 06:27 PM
Onsite EJ8's Avatar
you should replace the piston so you can have your motor running straight with no problems (hot spots)
spoolinvtec54
Engine Machining & Assembly
11
Nov 10, 2016 09:31 AM
fitseries3
Nov 11, 2013 04:57 PM
FATBOYeg6
Mar 17, 2008 02:17 PM
opticnerv
Welding / Fabrication
26
Feb 6, 2008 07:26 PM
gisserhatch
Dec 20, 2007 03:09 PM
