wiring Gurus.... please help!!!!
Old Jun 26, 2007 | 07:02 PM
J-specCb4's Avatar
Default wiring Gurus.... please help!!!!
so i just finished a jdm h22a swap into my cb7(90-93) accord and while everything works the injectors wont fire..... ive tested and switched out the injector resistor and the ecu... still nothing i checked all grounds. the timing is dead on, and compression is good... the fuel rail is getting fuel and pressurizing to 35 psi with the ignition key switched to ON... if anyone has any idea what the issue may be id appreciate any offers of knowledge lol.... been messing with it for a few days now and its getting pretty frustrating....
thanks in advance! h
Old Jun 26, 2007 | 07:26 PM
Suck my DX's Avatar
Default Re: wiring Gurus.... please help!!!! (J-specCb4)
are they getting power?
Old Jun 26, 2007 | 07:32 PM
J-specCb4's Avatar
Default Re: wiring Gurus.... please help!!!! (Suck my DX)
not from what i can tell but it was recently brought to my attention that a test light wont yield any results either way.... so at this point im kinda lost and almost ready to start chasing wires....
Old Jun 27, 2007 | 04:03 PM
Suck my DX's Avatar
have you tried listening to them with a long screwdriver?
Old Jun 28, 2007 | 07:30 PM
slowcivic2k's Avatar
Have you check to see if your getting spark? No spark.... no fuel.... no running car.....
PCM will disable fuel until it knows the ICM is sparking the plugs...
If your not getting spark let me know, I've already done about 9 write-ups on this subject, might as well do another...
Old Jun 28, 2007 | 07:34 PM
Humble Performance's Avatar
Default Re: wiring Gurus.... please help!!!! (slowcivic2k)
Have you checked your main relay ?
justhatched231
Feb 4, 2016 12:00 PM
ek4dave
Jan 21, 2014 10:40 PM
schramaj
Jan 3, 2013 03:37 PM
96-EJ6 B18C
Apr 15, 2004 05:33 PM
