wiring an 97 integra gs model
my ecu is getting reprogrammed by katman from ff squad. now my question is since its an obd1 ls p75 ecu and its getting reprogrammed to run a vtec motor how would i wire the vtec solenoid to my ecu i got the obd2 to ob1 jumper from jhpusa.com like what wires do i need to had and how can i do it my self???????? i really dont know anyone out here in bakersfield cali. thats why im here, thanks guys
ima post the diagram
*thanks to ff squad for the first part of the diagram*
find the wire to A4, cut it or slice it and wire it to the solinoid
find the wire to d6, cut it or splice it to the vtec pressure sensor, then on the vtec pressure sensor, wire the ground (black) to the engine. that is how simple it is to wire vtec
Modified by civicstar at 10:57 AM 3/19/2008
with my ecu, i cut the wires on the jumpers so i wouldnt have to install wires on my other harness, use butt connectors and crimp it down on the ends and wire like the diagram
ilovemyb16a
May 18, 2006 12:58 PM
juicy.koreans.suck
Dec 25, 2001 01:54 PM
