will these rods work?
Old Jan 5, 2009 | 02:41 AM
xander1100's Avatar
Default will these rods work?
im switching over from a b20 to a b18c and im curious if my old eagle rods will work. my old rods are 5.394 inches in length and the GSR ones are 5.430.
Old Jan 5, 2009 | 03:23 AM
GhostAccord's Avatar
Default Re: will these rods work?
Check the BE width of your B20's. I think it is 23.75mm and the B18C's are 21.8mm. I would say that in order to run your old rods in a B18C you will require a piston with a custom wrist pin location (or go with the stroke 1mm short) and a B18C crank with the main journals widened. I am not a B guru. I'm only going off a comparison of the spec sheets for the two rods.
Old Jan 5, 2009 | 02:31 PM
xander1100's Avatar
what effect will a 1mm short stroke have on the engine? will it damage it at all or just lower HP a little?
Old Jan 5, 2009 | 04:30 PM
It will drop your compression, lowering HP and the overall performance of the engine. For example if you had the B18C w/10:1cr. Using the shorter B20 rods would drop your compression to 9:1. I still think the larger BE width of the B20 rod would pose more of a problem if you use the B18 crank.
Old Jan 5, 2009 | 04:57 PM
NJIN BUILDR's Avatar
Like he said,the rods have a different length and big end width.They are not interchangeable.Sell the ones you have and by the ones you need.You may even find some one that will trade with you.
Old Jan 6, 2009 | 12:31 AM
xander1100's Avatar
cool thanks for the info.
Stakis
18
Apr 24, 2018 06:34 PM
speedciv
Jun 22, 2013 11:15 AM
hispanic panic
Acura TL, RL & ZDX
Dec 17, 2003 02:45 PM
gsr98vtec
Jan 11, 2002 05:16 AM
