will a p28 chip run a p75 ecu?????
Old Feb 16, 2004 | 04:09 PM
hybridb18's Avatar
Default will a p28 chip run a p75 ecu?????
i have my p75 socketed and ready to burn a chip, but my romulator wont seem to get the ecu to work. I have a chipped p28 layin around, and i was thinking bout trying that p28 chip in the p75 to make sure the p75 ecu was socketed correctly. So will the p28 chip work???
Old Feb 16, 2004 | 04:36 PM
RedlinedVTEC's Avatar
Default Re: will a p28 chip run a p75 ecu????? (hybridb18)
Not going to work well for youif it will even start and idle what are you using to burn chips and what software are you using?
Old Feb 16, 2004 | 05:58 PM
TRuST's Avatar
NO won't work. You'll check lites the moment you start it.
Old Feb 16, 2004 | 09:24 PM
hybridb18's Avatar
Default Re: will a p28 chip run a p75 ecu????? (TRuST)
well, i went ahead and tried it, and it started right up with a check engine light, but it was running in Limp Mode. Does the p28 run on a diff code than a p75??? Im just tryin to make sure my soldering jub is good.
I was trying to get the ecu to run using a xtronics romulator using uberdata software, but no luck at all. All it would do is crank over
Old Feb 17, 2004 | 07:11 AM
mmuller's Avatar
Mad Scientist
mmm.
p28=vtec ecu
p75=non vtec ecu
you do the math
david268
Engine Management and Tuning
Jan 27, 2018 09:40 PM
Jap_Spec_Imports
Oct 29, 2009 08:32 PM
blackcivic11
17
Jul 24, 2009 01:32 PM
