will .5 compression make any different?
Old Nov 2, 2003 | 05:21 AM
SupaFly_Honda's Avatar
Default will .5 compression make any different?
just like the topic says.
will you notice know difference between a 11:5 and 12:0 compression?
Old Nov 2, 2003 | 11:30 AM
MachAF's Avatar
Default Re: will .5 compression make any different? (SupaFly_Honda)
yes. 5% power increase.
Old Nov 2, 2003 | 11:42 AM
7thGear's Avatar
Default Re: will .5 compression make any different? (MachAF)
as well as the chance for a detonation assuming stock tuning.
Old Nov 2, 2003 | 11:52 AM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">yes. 5% power increase.</TD></TR></TABLE>
I thought it was more like 5 hp. I always thought 1.0cr was about 10 hp.
Old Nov 2, 2003 | 12:18 PM
ryanstev's Avatar
Default Re: will .5 compression make any different? (Ricey McRicerton)
I heard it's about 8% increase every one point increase. So for my car going from 9:1 to 10:1 will give me 8% more hp.
Old Nov 2, 2003 | 04:49 PM
Default Re: will .5 compression make any different? (ryanstev)
it makes power but not worth the chances of detnotation?
Old Nov 2, 2003 | 08:44 PM
blackeg's Avatar
yea see im interested in this too. is there a real set in stone anwser to this question cause ive heard all kinds of differnt answers. i just raised my compression in my d16 from 9.2 to about 9.6. car feels a little stronger but i cant relate it directly to compression increase cause i had alot of other work done at the same time..
Old Nov 2, 2003 | 08:50 PM
Kendall's Avatar
The usual rule of thumb when dealing with Honda motors is: per point of compression increased, horsepower increases by about 10. A 5 horsepower increase sounds correct. If it's a vtec motor maybe 6 or 6.5 horses, if it's not then maybe only 4. It all depends on the motor, the mods done to it, and the condition it's in. If you raise the compression be sure to use premium and maybe octane boost to insure against knocking and detonation.
Old Nov 3, 2003 | 12:27 AM
Katman's Avatar
Default Re: will .5 compression make any different? (blackeg)
Yep, I'd have to agree, you can barely 'feel' .5 of added compression. It's hardly noticeable if you're into the ***-dyno.
Turbofrancis619
Sep 4, 2008 06:18 AM
patriot
13
Aug 23, 2008 03:19 PM
91integraLSVTEC
Aug 14, 2006 04:06 PM
JO
Jan 16, 2004 12:40 PM
Greyout
Apr 24, 2002 04:13 PM
