Wierd noise!
Old Nov 25, 2002 | 11:18 AM
bokguay's Avatar
Default Wierd noise!
When i brake...there is this noise coming from the left caliper and it makes a grinding noise but only in 1 second intervals...likeit hits a certain spot on the rotor and u hear it...a shop told me it is the wheel bearings but i really dont believe it is....do u guys know what it might be?
Old Nov 25, 2002 | 11:27 AM
Spade's Avatar
Default Re: Wierd noise! (bokguay)
You check your wheel bearings by jack that side off of the ground.
Place your hands on 12 and 6 and attempt to wiggle the wheel. If it moves, inspect your ball joints on the control arms. If they are good. It's your bearings.
Old Nov 25, 2002 | 12:35 PM
bokguay's Avatar
Default Re: Wierd noise! (Spade)
i juss PM ed u
Old Nov 25, 2002 | 03:11 PM
artifex's Avatar
say it
bad wheel bearings make a constant oscillating noise while at speed (40-75), at least in my experience. with an intermittent noise only under braking, i'd say your rotors are warped. mine were warped in the rear and they make a god-awful intermittent scraping noise just like what you describe. hope that helps.
Neil
[Modified by artifex, 6:12 PM 11/25/2002]
bambbrose
Oct 11, 2015 08:01 AM
avio
Apr 16, 2010 12:51 AM
Mr.Luder
Oct 16, 2007 03:54 PM
pghz_last_don
Dec 8, 2006 07:58 PM
Simonak15
Suspension & Brakes
Apr 19, 2006 03:41 AM
