why would I have to plug the oil squirters?
Old Sep 22, 2004 | 05:20 PM
cygnusX1's Avatar
Default why would I have to plug the oil squirters?
I just heard that if you put an LS crank in a GSR block, you'd have to take off or plug the oil squirters because the rods would come into contact with them. true?
Old Sep 22, 2004 | 05:44 PM
rgbpmp's Avatar
Default Re: why would I have to plug the oil squirters? (Haleiwa-Brando)
I heard this is true.
And im slightly sad looking at that picture.
Old Sep 22, 2004 | 05:45 PM
gabhatch's Avatar
Default Re: why would I have to plug the oil squirters? (cygnusX1)
yeah its true on most stroker moters so probably
Old Sep 22, 2004 | 07:56 PM
mchuang's Avatar
I know on a b16 when you put a ls crank in it you have to do that because the 89 stroke ls crank touches the squirters. You have to weld up the small hole in screw though so the block motor can hold pressure. If you dont do that then vtec wont come on
Old Sep 22, 2004 | 07:59 PM
cygnusX1's Avatar
Default Re: why would I have to plug the oil squirters? (gabhatch)
well what the ****... someone tell me it isn't true. this is brutal, come on honda!?!?!?!?!
Old Sep 22, 2004 | 08:00 PM
cygnusX1's Avatar
Default Re: (mchuang)
SgT said that the B16 dosn't have squirters...
Old Sep 22, 2004 | 11:17 PM
wHOAlly's Avatar
Default Re: (cygnusX1)
on some motors the ls crank does hit the squirter, u could bend them up, but if its built motor, the internals are deisnged to handle the abuse w/o oil squirting on em, so to me it seems more hassle than anything...
i plugged mine
drill em out, tap with 1/8npt, and plug em
Old Sep 23, 2004 | 06:31 AM
mchuang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cygnusX1 &raquo;</TD></TR><TR><TD CLASS="quote">SgT said that the B16 dosn't have squirters...</TD></TR></TABLE>
Wtf. Has he ever seen an open b16 block. It has squirters. Even turbo DSM's have squirters.
Old Sep 23, 2004 | 06:50 AM
Power Rev Racing's Avatar
If you have a GSR block you can use a LS crank. All you have to do is tap the oil squitters up alittle bit. I did a build like this 2 months ago, and it runs find. No problems with rods hitting oil squitters.
Before i bended the squitters. If you try to spin the crank, you will realize that the crank does touch the squitters, and would probly rip one out when spinning fast. Just hit it down a notch, and its all good to go.
Old Sep 23, 2004 | 08:26 AM
93lsd's Avatar
this is true i just put my block together gsr with ls crank and the counterweights hit the squirters. i just pluged the up and so far no problems
Old Sep 23, 2004 | 08:45 AM
StyleTEG's Avatar
Default Re: (Power Rev Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote"> All you have to do is tap the oil squitters up alittle bit.
At that point they are no longer pointing at the bottom of the piston/wrist pin, no?
Old Sep 23, 2004 | 10:14 AM
Default Re: (StyleTEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StyleTEG &raquo;</TD></TR><TR><TD CLASS="quote">
At that point they are no longer pointing at the bottom of the piston/wrist pin, no?</TD></TR></TABLE>
It will no longer be aiming at the exact same spot, but the little bit that you have to tap it will not have it spraying at the cylinder wall or anything. It will only be off my mm's
Old Sep 23, 2004 | 04:49 PM
cygnusX1's Avatar
Default Re: why would I have to plug the oil squirters? (93lsd)
ok... thanks for the info, now... is it even worth it to put the LS crank into the GSR? Looking at the dyno charts from importreview.com there isn't a lot of difference in torque between similar powered cars. I know that different mods will produce different HP and torque numbers, but, is the crank worth the little bit of torque over the better rod ratio of the B18c?
Old Sep 24, 2004 | 09:29 PM
Octoman's Avatar
I wouldn't think that it would be worth the effort or the expense. Put that money into making more power and torque from your GSR motor. Why don't you add some higher compression pistons to help with the HP and TQ numbers. Besides, wouldn't you have to switch to ls rods?
Old Sep 25, 2004 | 06:51 AM
dome's Avatar
yes you do have to remove the oil squirters. i have a ls crank in a gsr block bored to 84mm. has sleeves, crower rods, wisco pistions. befor we put the motor in we took the oil pan off just to make sure the builder put everything in. we spun the crank over and notice that 3 of the 4 were hitting the pistions or crank. we called the builder and bitched him out and he came down and pluged them. oil pressure goes up. this guy is a real **** head did nt check the clearances on the bearing either. motor is out and being fixed. i know i was in trouble when i saw the squarters. take them out and plug them. if it is built you will be fine forged parts of corse. 400hp@15lbs 250lbs tq
GaVO311
Sep 20, 2006 05:56 PM
slowassciv33
Apr 21, 2006 08:54 AM
blu3g
26
Aug 2, 2005 09:22 PM
1heavy4dr
Jul 26, 2005 05:26 PM
vteczone
Nov 24, 2004 12:22 AM
