Old Apr 6, 2015, 10:00 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Why is my VTEC solenoid valve leaking?
Old Mar 1, 2010 | 08:50 AM
  #26
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Why is my VTEC solenoid valve leaking?
Yeah I used brake cleaner on the whole area last weekend, which is how I traced the leak to the gasket in between the VTEC valve and solenoid, NOT the gasket between the valve and the engine head.
Old Mar 1, 2010 | 10:44 AM
  #27
dudesitsjdm's Avatar
well seems like you found the leak bet you feel better lol
Old Mar 1, 2010 | 10:59 AM
  #28
Community Builder
I dunno, I'll feel better when the damn thing is actually fixed.
I'm a bit of a perfectionist and can't stand even the smallest leak of any sort.
Old Mar 1, 2010 | 11:25 AM
  #29
  #30
well gl man
Old Mar 1, 2010 | 07:09 PM
  #31
Community Builder
VTEC oil leak seems to be gone. However it appears there is still oil leaking from other places and dripping down onto and burning on the exhaust header, as I explained in this thread: https://honda-tech.com/forums/tech-misc-15/found-more-oil-leaks-oil-dipstick-2736333/
Old Jan 4, 2020 | 11:43 AM
  #32
Timothy Sweeney's Avatar
Originally Posted by PatrickGSR94
oh crap, #25 in this pic right? I didn't even think about that!
*calls up Carland Acura to get it added to order*
Any idea where I can find the picture? I'm having trouble with this in 2020. Thank you.
Old Jan 5, 2020 | 02:54 PM
  #33
Community Builder
#25 in this diagram is the O-ring in question.
https://www.acuraautomotiveparts.org...ylinder-head-2
Old Jan 6, 2020 | 10:49 AM
  #34
muellersfan's Avatar
You can usually fix the leak without buying new gasket and instead (1) cleaning old gasket and solenoid mating surfaces with brake cleaner and (2) applying a thin layer of HondaBond to the gasket. Then torque to spec.
Old Jan 6, 2020 | 04:38 PM
  #35
Thank you. Local Honda parts department helped me figure out the o ring and top gasket, not just the one with the filter and problem solved. I didnt even have to take anything off but the wiring harness for those two fixes on day 2. Keeping my 99 rolling. I truly appreciate the replies and glad this thread was still alive.
Old Jan 21, 2025 | 12:14 AM
  #36
Eightball88's Avatar
This is a result of further inspection after this thread: https://honda-tech.com/forums/tech-misc-15/what-else-can-cause-oil-leak-near-cam-plug-distributor-2732064/
This is the oil I'm seeing dribbling down the front of the block and trans bell housing.
Attachment 464017
I looked closer and could definitely see oil on the bottom of the VTEC solenoid valve housing. I just installed a new valve gasket w/ screen the other day, due to leaking, but now it seems worse. I would say the previous gasket/screen was only on there for a couple of years.
This shows the oil on the valve housing.
Attachment 464018
Looking closer at the solenoid portion, I don't see any oil coming from the solenoid gasket area.
Attachment 464019
Attachment 464020
Attachment 464021
Attachment 464022
Attachment 464023
Did I just completely botch the install? Or could the gasket be defective? Helms calls for 8.7 ft-lbs on those 3 housing bolts. I might have taken them to 10 ft-lbs. Could over-tightening cause the housing to leak? I re-installed the housing tonight and was careful to go only to 9 ft-lbs on my Craftsman Digitork torque wrench (it was either 8.5 or 9 so I chose 9).
It only leaks when the engine is running so we'll see how it looks after I drive to work tomorrow.
Just figured out this was from 2010. But hey. Still having the issues. And it's a faulty thing that darn vtec solenoid mine leaks when it super cold out.
Old Jan 21, 2025 | 11:18 AM
  #37
Community Builder
wow, I forgot about this thread.
So, some additional info I've learned over the years. If you look at my pics in the original post #1 on the previous page (pic #5 specifically), you can see that the cam plug (the revised plastic version with an o-ring), is not aligned with the top of the cylinder head mating surface. I didn't realize until a few years ago that the hash marks on that cap/plug should align with the mating surface between the head and valve cover, according to the 98-01 Integra Helms service manual.
Also, for many years I was actually missing the RTV sealant that goes in between the 2 cam caps that hold that cap plug and the distributor. Without that sealant, oil can work its way in between the camshaft/plug and the valve cover gasket. The sealant has to be applied to the bottom side of those caps during installation, in addition to the RTV sealant that goes on the corner of the valve cover gasket. I believe this was the main source of oil I was seeing in that area between the camshafts and around the VTEC solenoid, for all those years. Once I applied the correct sealant, no more leaks. Like for real this time.
Master23
17
Apr 1, 2018 08:48 AM
djkurious
Mar 3, 2014 07:01 AM
NJ-JDM
Oct 23, 2013 02:54 PM
Master23
Jun 5, 2006 07:34 PM
bboylito
Mar 3, 2005 04:14 AM
