whistle from throttle body
Old Feb 17, 2003 | 07:29 AM
dxcivic's Avatar
Default whistle from throttle body
hey all i have a 97 civic dx.. and ever since i put on my intake there has beena whistle comming from the throttle body.. now is there anyway to get rid of this? besides buying a new throttle body (which i might anyway cuz the dx one is soo ugly) does anyone know what causes this?
Old Feb 17, 2003 | 07:39 AM
Hybridhonda561's Avatar
Default Re: whistle from throttle body (dxcivic)
Well it sounds normal. Does it wistle when you shut the car off. That sound is just the air being sucked in thru the TB. Double check you dont have a vacuum leak to. tighten the screws. also it is because when you put an intake on your also getting rid of the air sliencer on the stock intake. Correct me if im wrong but its seems normal.
[Modified by Hybridhonda561, 4:40 PM 2/17/2003]
Old Feb 17, 2003 | 08:13 AM
dxcivic's Avatar
Default Re: whistle from throttle body (Hybridhonda561)
im pretty sure its not a vacuum leak.. it happens at a certain point when the butterfly is open
Old Feb 17, 2003 | 08:18 AM
Other than it just being the sound of air being sucked in i dont know.
Old Feb 17, 2003 | 09:42 AM
1bad-eg's Avatar
Usually happens when using aftermarket intake. Some intakes whistle alot louder than others.
Old Feb 17, 2003 | 10:09 PM
MIRRAdekhtc's Avatar
Default Re: whistle from throttle body (1bad-eg)
check the rubber cup connecting the intake tube to the throttle body.
on my 97 civic ex, it whistled like that, every civic, especially 92-95, makes a whistling noise, but mine was a high pitched whistle, anyways the rubber cup on the throttle body was alittle tilted downward and the hose clamp wasn't fully tightened, like a 1/16 of an inch gap and it was sucking air in between it, thru that little gap, causing the high pitched sound, readjusted it, tightened completely and it fixed it.
Old Feb 17, 2003 | 10:10 PM
EK MONEY's Avatar
Default Re: whistle from throttle body (MIRRAdekhtc)
I have one too. I think it was my intake
Old Feb 18, 2003 | 04:39 PM
slvrcivic97's Avatar
Default Re: whistle from throttle body (Peagreenhatch)
It happens ALOT with AEM CAI's. It happened to me (97 civic dx coupe). All you do if you don't like it becuase it does get annoying is adjust the idle valve on your tb. It will fix it.
Old Feb 18, 2003 | 04:59 PM
mugenracer's Avatar
Default Re: whistle from throttle body (slvrcivic97)
It used to happen on my short ram intake and i loved it, but then i cleaned my IAC valve out and it stopped!!! i was sooooooooo pissed off that i blocked up the IAC again with tissue paper!
Old Feb 18, 2003 | 05:11 PM
Katman's Avatar
If you messed with/adjusted the Idle Adjustment screw on the TB, that could be the culprit; at least it was in previous cases I've encountered.
What you want to do is completely remove the idle-adjustment screw and put some honda bond around it, then put the idle-adjustment screw back into the the TB, and that should make that damn whistling going away.
Old Feb 18, 2003 | 06:28 PM
lazy bum shaughn's Avatar
Man it's normal, especially for cold air intakes. Just get an exhaust and you wont hear that whistle no more.
SSGojeta
Dec 27, 2008 09:29 AM
memorybox
Sep 19, 2006 11:07 AM
Project_Civic
Apr 3, 2005 05:16 PM
1sikhatch
Feb 20, 2005 08:43 AM
