While im going down on her !
Old Feb 25, 2004 | 12:57 AM
Willie VTEC's Avatar
Default While im going down on her !
I am changing the clutch and flywheel on my JDM GSR to JDM Type R Spec.
What else can I do while I am down there.
I am going to replace
(i) Pilot Bearing
(ii) Rear Main Seal
Can I reuse the flywheel bolts?
Any other info would be most welcome
Go Raibh Maith agat
Willie
Old Feb 25, 2004 | 05:21 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: While im going down on her ! (Willie VTEC)
if the new flywheel is used, be sure to have it resurfaced. you should be able to reuse the flywheel bolts as well. you can always change your tranny fluid, instead of reusing the old stuff.
numotive
Sep 21, 2005 04:37 PM
bboylito
Apr 30, 2005 10:27 PM
snatch
Aug 20, 2004 09:56 AM
EF9Si-T
Mar 20, 2004 08:56 PM
3rdGteg
Sep 3, 2002 09:52 PM
