where is the PCV valve on a b16?
Old Sep 23, 2002 | 06:03 PM
keebler65's Avatar
Default where is the PCV valve on a b16?
its a first gen b16. i thought it was usually inline with where the breather hose goes from the valvecover to the intake. i dont see it. yes i did a search btw
thanks
Old Sep 23, 2002 | 06:05 PM
enhancedCL9's Avatar
Default Re: where is the PCV valve on a b16? (keebler65)
Underneath the fuel rail on the Intake manifold.
Old Sep 24, 2002 | 07:12 PM
keebler65's Avatar
Default Re: where is the PCV valve on a b16? (thizguy)
thanks!
Old Jan 25, 2003 | 12:09 PM
T_Rex's Avatar
Does anyone have a picture or diagram of the location of the PCV valve? Thanks.
[Modified by T~Rex, 5:48 PM 1/27/2003]
Old Jan 27, 2003 | 04:48 PM
T_Rex's Avatar
Default Re: where is the PCV valve on a b16? (T~Rex)
Old Jan 27, 2003 | 05:03 PM
Kataku2K3's Avatar
The acutal PCV will be located in the intake manifold... Trace the line down off the intake manifolds plenum till right where it goes flush with the runners... You'll see a little 90 degree plastic piece.... That's ur PCV valve.... Good Luck
Old Jan 27, 2003 | 06:59 PM
FitCRX's Avatar
Default Re: where is the PCV valve on a b16? (Kataku2K3)
What pvc valve are you guys replacing the stock b16a1 valve with?
Old Jan 27, 2003 | 07:00 PM
slomofo's Avatar
GDD Member
Default Re: where is the PCV valve on a b16? (FitCRX)
I'm pretty sure the B16A2 valve will work.
Old Jan 27, 2003 | 07:37 PM
T_Rex's Avatar
Default Re: where is the PCV valve on a b16? (slomofo)
Is aftermarket OK, or do I need to use an OEM Honda one?
Old Jan 27, 2003 | 09:02 PM
FitCRX's Avatar
Just about any pvc valve can be modified to fit, but which has the corrrect flow rate?(if it can be called that) I think this question can only be anwsered by a qualified honda technison*.
Old Jan 27, 2003 | 09:48 PM
Kataku2K3's Avatar
I would just go with OE, they're not that expensive anyways... Latez
Homotor
Jan 21, 2008 10:19 PM
ApolloSpeed
Aug 11, 2005 08:05 AM
2lobes1engine
May 12, 2004 07:56 PM
NINJASPY
Mar 4, 2004 02:59 PM
riceball777
Feb 16, 2004 11:53 PM
