where does the wire that grounds the thermostat end up?
Old Oct 8, 2002 | 07:41 AM
civbeater90's Avatar
Default where does the wire that grounds the thermostat end up?
ok ugys i have a 90 si.the ground on the thermostat was bad so i ground it to the frame.where does the wire go ?basically where does it lead to inside the wire harness?thanks any help would be great
Old Oct 8, 2002 | 10:55 AM
DarkSubRosa's Avatar
Default Re: where does the wire that grounds the thermostat end up? (civbeater90)
not sure exactly, but i know if its not tight it can make your car do some really stupid stuff and not run.
jvr
Apr 11, 2014 11:56 PM
blackpearlv6
May 23, 2006 08:27 AM
AllmotorEH2
Welding / Fabrication
Feb 28, 2005 08:48 PM
