wheel bearing/hub/knuckle?
Old Feb 20, 2004 | 10:19 PM
92civeg's Avatar
Default wheel bearing/hub/knuckle?
does anyone know of any companies that sell hubs with the wheel bearing pressed in them already...i need new wheel bearings in front and i got quoted at 175 per side, so im wondering if just buying new hubs withe the bearing already in them would be cheaper..or does the wheel bearing get pressed into the knuckle?
.thanks
Modified by 92civeg at 4:00 PM 2/22/2004
Old Feb 21, 2004 | 07:29 PM
92civeg's Avatar
Default Re: wheel bearing/hub/knuckle? (92civeg)
up
Old Feb 22, 2004 | 07:07 PM
92civeg's Avatar
anyone?
Old Feb 22, 2004 | 07:32 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know of any companies that sell hubs with the wheel bearing pressed in them already...i need new wheel bearings in front and i got quoted at 175 per side, so im wondering if just buying new hubs withe the bearing already in them would be cheaper..or does the wheel bearing get pressed into the knuckle?
.thanks
yes, the wheel bearing normally gets pressed into the hub of the knuckle assembly, when being replaced. Wheel bearings, by themselves, are kinda pricey to begin with.
$$-wise, you might be better off finding a used pair of knuckle/hub assemblies for your car.
Old Feb 22, 2004 | 07:34 PM
92civeg's Avatar
Default Re: wheel bearing/hub/knuckle? (Katman)
cant i just buy hubs with the bearings already in them...i know ive seen them i just dont know where
Old Feb 22, 2004 | 08:28 PM
the DR.'s Avatar
I don't think you will find any hubs with wheel bearing assembled, since the bearing needs to be pressed into the knuckle first, then a snap ring installed, then the hub pressed into the bearing (UNLESS you are refering to the rear)
Old Feb 24, 2004 | 11:21 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg &raquo;</TD></TR><TR><TD CLASS="quote">cant i just buy hubs with the bearings already in them...i know ive seen them i just dont know where</TD></TR></TABLE>
I believe you can, by an aftermarket company, I'm just NOT sure on who make them.....I've seen them too, just can't remember...I think it might Ground Control who made some aftermarket knuckle assembly.
IF you want to buy brand new OEM knuckle/hub assy. you're gonna spend some big time $$$.
Modified by Katman at 1:50 PM 2/26/2004
Old Feb 24, 2004 | 06:18 PM
92civeg's Avatar
i just need 2 new front bearings... but i thought i saw them in the hub somewhere...for pretty cheap
Old Feb 24, 2004 | 08:25 PM
turbohondask's Avatar
i have a integra set of knuckles with brakes for 150
Old Feb 25, 2004 | 04:24 PM
92civeg's Avatar
Default Re: wheel bearing/hub/knuckle? (turbohondask)
i want new ones
Old Feb 25, 2004 | 08:00 PM
f@sth@tch89's Avatar
http://www.turbomagazine.com/t...h.jpg
check out: http://www.nitrodriveline.com/
http://www.turbomagazine.com/tech/0205tur_unbreak/
Old Feb 26, 2004 | 12:33 PM
92civeg's Avatar
Default Re: wheel bearing/hub/knuckle? (fasthatch89)
they dont sell just a hub though do they?(i couldnt find one)....would those be compatible with my stock equipment?
Old Feb 27, 2004 | 12:45 PM
MightyMouseTech's Avatar
You can't do it. You have to press the bearings into the knuckle FIRST, install the snap ring, THEN press the hub into the bearing. There is no other way of doing it.
Old Feb 27, 2004 | 01:00 PM
DOMKID's Avatar
Default Re: wheel bearing/hub/knuckle? (MightyMouseTech)
you can always buy front gsr brakes for about 200. from places like
jdmhondparts.com
jdmshit.com
passwordjdm.com
Old Feb 27, 2004 | 05:56 PM
x2gold's Avatar
Default Re: wheel bearing/hub/knuckle? (Dominican_Kid)
do it like they say, u need a nice press, ...also when your hub is out, u can put longer studs in . I just did this a few days ago, both fronts. The bearings were 40 each, which isnt' that bad. I also replaced all the studs while there. Luckily the shop is real cool and let me do it there, so i removed the old bearings, studs, snap ring there, and pressed em in. They just charged me 20$ for using the press and 8 bucks for studs and nuts ...hella good deal.
Old Feb 27, 2004 | 08:32 PM
92civeg's Avatar
Default Re: wheel bearing/hub/knuckle? (x2gold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x2gold &raquo;</TD></TR><TR><TD CLASS="quote">do it like they say, u need a nice press, ...also when your hub is out, u can put longer studs in . I just did this a few days ago, both fronts. The bearings were 40 each, which isnt' that bad. I also replaced all the studs while there. Luckily the shop is real cool and let me do it there, so i removed the old bearings, studs, snap ring there, and pressed em in. They just charged me 20$ for using the press and 8 bucks for studs and nuts ...hella good deal.
where did u get the bearings from?
z6hatchboy
Feb 6, 2009 06:31 PM
Nisif
Dec 4, 2006 04:03 AM
XJamesX
Suspension & Brakes
Jun 1, 2005 12:41 PM
nwdrifter
Sep 28, 2004 12:15 PM
