What's VTEC match fuel correction?
Old Jan 22, 2002 | 02:50 PM
evo's Avatar
evo
New User
Default What's VTEC unmatch fuel correction?
In VAFC there're VTEC unmatch fuel correction, has anyone know what that is, Thanks.
[Modified by evo, 12:06 AM 1/23/2002]
Old Jan 22, 2002 | 04:45 PM
civiksi's Avatar
Default Re: What's VTEC unmatch fuel correction? (evo)
Its when you change the VTEC switchover rpm, you can decrease/add fuel to the rpm difference. Like if you set it to 5k, you can richen up those 500 rpms, since it would be leaner, since vtec would start until 5500 rpms. Sorry this is a crappy explanation
[Modified by civiksi, 1:46 AM 1/23/2002]
[Modified by civiksi, 1:47 AM 1/23/2002]
Old Jan 23, 2002 | 06:12 AM
evo's Avatar
evo
New User
Default Re: What's VTEC unmatch fuel correction? (civiksi)
Thanks for reply! But only option is +-0% rather +-rpm, is that mean the percentage of the VTEC engage point?
e.g 5000rpm VTEC engage, if set +1%= 5000x1.01=5050, is that mean the fuel supply'll be 5000rpm = 5050rpm?
Hope you understand what i mean.
Old Jan 23, 2002 | 10:19 AM
John's Avatar
New User
i thought the unmt fuel correction was the fuel correction for that rpm gap that your car will remain in VTEC... for instance, there are two settings for VTEC (VTEC cnt) on the V-AFC: 1) the rpm that VTEC engages during acceleration (L H), and 2) the rpm where VTEC disengages (H L)... now i thought that the VTEC unmt was the fuel correction rate between those two periods H>>L and L>>H...
does this sound correct?
Old Jan 23, 2002 | 12:17 PM
evo's Avatar
evo
New User
Default Re: What's VTEC unmatch fuel correction? (DunReit)
Do u normally set L H in + or -?
Old Jan 23, 2002 | 12:39 PM
John's Avatar
New User
i set it at 3%, however, i don't know if really did anything... i was told somewhere by someone that the at the VTEC threshold, there should be a little richer mixture b/c of the power spike, but the validity of that recommendation is unknown...
Old Jan 23, 2002 | 06:39 PM
John's Avatar
New User
oh yeah, i posted this topic awhile ago... kind of the same inconclusive answer...
https://honda-tech.com/zerothread?id=90782
slimx
Engine Management and Tuning
Jun 15, 2013 01:25 PM
apgarabu
May 25, 2005 06:15 AM
HoUTX98GSR
May 7, 2005 08:22 AM
ahunt01
May 9, 2003 08:02 AM
