what's the problem?
Old May 27, 2003 | 06:25 AM
ekferio's Avatar
Default what's the problem?
To start off, I was wiring my CTR citylights. I had the ground wires of the citylights hooked up to those bolts with other factory ground wires. Second, I was testing the citylights (5w) and headlights (7500K) without turning my car on. But I did it for about 2 minutes max. I also left my radar scanner plugged in all night. Now I'm not sure which one of the above caused the problem, but my car died one time when idling for a red light. I was also low on gas at the time (no light came on). Did I drain my battery from testing the headlights?
Old May 27, 2003 | 06:27 AM
ekferio's Avatar
Default Re: what's the problem? (civicek2)
one more thing...when I was wiring my citylights I disconnected the negative cable on the battery, but I did not let my car re-learn the ECU after re-connected it. Could this be a problem?
Old May 27, 2003 | 09:39 AM
Crazydave's Avatar
maybe you ran out of gas..
my gas light doesn't come on any more..
maybe your fried your alternator..
and your car died because you have no more juice in your battery
Old May 27, 2003 | 09:40 AM
Nextelbuddy's Avatar
Default Re: what's the problem? (Crazydave)
hard to say
Old May 27, 2003 | 09:57 AM
ekferio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave &raquo;</TD></TR><TR><TD CLASS="quote">maybe you ran out of gas..
and your car died because you have no more juice in your battery</TD></TR></TABLE>
i think you are right sir...i did almost run out of gas ha but my radio was working when the car died
aztec34
Jul 14, 2011 11:49 AM
VTECROAR96typeR
Sep 9, 2009 06:03 PM
xkwzt21
32
Jan 11, 2005 05:43 PM
Fowler.
10
Aug 20, 2004 05:26 PM
Sivic_Hatch
Apr 20, 2003 11:41 AM
