whats a good header for a b20vtec project
Whats up honda tech , Ive been hearing mixed reviews about various headers like: mugen , jvtr, ssmp , hytech, comptech etc. anyways the point is that im looking for a good header that would help produce good power and low end torque. I have a b20vtec with alot of upgrades. 70mm sk2 throttle body, ported sk2 intake manifold, port and polished head , supertech valvetrain, on the bottom end im working with 12:5-1 comp. pistons , eagle block guard, eagle forged rods, 27lbs eagle crank, acl race bearing , golden eagle block girdle, 12lbs act flywheel , stage 2 exedy clutch etc. etc.
I want a header thats going to help me produce good numbers and better lower torque to compensate for the 27lbs crank. let me know im open to all opinions. thanks
if you want low end power, then you may as well get rid of the 70mm tb and get something a bit smaller. as for the header, i personally like the hytech replica headers. they are great for the bang for the buck factor. im running the standard replica header on a gsr with skunk pro intake mani, and 2.25" dc exhaust, and the header realy seemed to give it a bit more low end compared to the 4-1 dc that i had on it. that is going by the famous butt dyno of corse lol.
i went with the larger throttlebody to help in the internal combustion more colder air equals more power plus more torque but what in not sure was about the header , i found in the web site theoldone hytech headers at $795 new maybe ill go with that or get a custom set for $1350.00 in the long run. Do you know about any good tuning shops? By the way i apreciate your advice thanks .
Im going to use a tanabe ultra medallion g spec exhaust. maybe a test pipe . Hey if your looking for a p28 hondata s300 ecu new lightning motorsports has them $530. shipped
I've been hearing alot of good things about the Hyptech Big Tube Headers. I was running my slightly moded B20v off of ITRs, but putting on the Big Tubes.
plzbeleiveit
28
Jun 7, 2008 05:10 PM
