what's the difference between b16 a1 and a2 bottom end?
Old Sep 12, 2002 | 06:30 AM
S2Kpower's Avatar
Default what's the difference between b16 a1 and a2 bottom end?
i know there is a slight difference in the head, but what about the bottom end? compression, bore, oiling characteristics? anyone? - Wallace
Old Sep 12, 2002 | 09:53 AM
thegrinch's Avatar
Default Re: what's the difference between b16 a1 and a2 bottom end? (S2Kpower)
Same thing just made in different years
Old Sep 12, 2002 | 09:58 AM
S2Kpower's Avatar
Default Re: what's the difference between b16 a1 and a2 bottom end? (thegrinch)
thanks
Old Sep 12, 2002 | 09:04 PM
Civic DX 4dr's Avatar
If you're referring to the jdm b16a then there are a few differences. The first gen b16 has slightly lower compression than the second, 10.2 to 10.4. Also the second gen has the oil squirters unlike the first gen. Someone correct me if im wrong.
Old Sep 12, 2002 | 09:57 PM
mannyman's Avatar
El Veterano de Sur Califas
Default Re: what's the difference between b16 a1 and a2 bottom end? (Civic DX 4dr)
you are correct about the compression. but about the oil squirters, i thought all bseries vtec motors had them.
Old Sep 12, 2002 | 09:59 PM
Choppa's Avatar
Default Re: what's the difference between b16 a1 and a2 bottom end? (mannyman)
the first gen B16 had different cooling properties.
The pistons from my understanding are the same.
CR is 10.2 for all delsols. The gain in HP was from different profiled cams.
Old Sep 12, 2002 | 10:37 PM
tinkerbell's Avatar
Default Re: what's the difference between b16 a1 and a2 bottom end? (Choppa)
OK, if you are refering to the B16A as hte B16A1 then this is how it is:
JDM B16A = 10.2:1
B16A2 = 10.4:1
both have oil squirters.
the A2 has crank sensor.
the Del Sol is an A2
some did have an oil cooler - some did not.
t..
Old Sep 13, 2002 | 04:32 AM
S2Kpower's Avatar
Default Re: what's the difference between b16 a1 and a2 bottom end? (tinkerbell)
integresting... pardon my ignorance, but what does the crank sensor do?
Old Sep 13, 2002 | 07:12 AM
osbornsm's Avatar
New User
It tells the ECU where the crank is in it's rotation.
Old Sep 13, 2002 | 10:04 AM
thegrinch's Avatar
A b16a1 also comes from a DEL SOL......... I use to have one. they came in the 94.
If I am correct the crank sensor didn't come until the 96+ models.(OBDII)
[Modified by thegrinch, 7:05 PM 9/13/2002]
Bradman
42
Jul 9, 2013 10:33 PM
lastturn
Nov 10, 2005 06:57 PM
Methane2k2
Mar 5, 2005 11:37 AM
thashadow
12
Nov 3, 2002 07:24 PM
paulzy
May 1, 2001 01:13 PM
